Do I need all of this for HU install?
Old Oct 6, 2006 | 06:39 AM
bklusa1's Avatar
bklusa1
Default Do I need all of this for HU install?
The audio shop is telling me I need to pick up a line level adapter to hook into wiring harness, instead of just getting the metra harness (claims they always get alot of noise without the use of the line level adapter), and an antenna adapter of some sort? Does this all sound correct, costing me about $80 just for the line level adapter, wiring harness, and antenna adapter....
Old Oct 6, 2006 | 06:44 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Does your aftermarket headend have line level outputs? If so you don't need the adapter. The antenna jack from the stock radio is a standard Motorola jack and plugs into every car radio ever made.
Old Oct 6, 2006 | 06:57 AM
bklusa1's Avatar
bklusa1
It's got Fr and Rear/Sub RCA's...... so I don't need the adapter? Just run metra straight off these?
Old Oct 6, 2006 | 06:58 AM
bklusa1's Avatar
bklusa1
Also, what resistance are the stock bose systems wired in...
Old Oct 6, 2006 | 07:40 AM
240Zplus110's Avatar
240Zplus110
I'm ordering an Alpine CDA-9857 HU and the shop also said I need an antenna adaptor -- is this true?? I thought all I needed was the Metra 70-7550 wiring harness.
Old Oct 6, 2006 | 07:56 AM
THEDUKE's Avatar
THEDUKE
That is a bunch of bull. You do not need an antenna adaptor. Some of the older Nissans needed it because they used a diversity antenna, but that is not true for our vehicles. Either they do not know enough to be installing or they are just trying to get extra money out of you. The only reason they would need some kind of line level converter is if you have a Bose system.
Old Oct 6, 2006 | 08:44 AM
240Zplus110
Thanks!! I figured the shop was trying to get extra money... maybe to make up for the great deal they gave me on the HU. I told them to only get the Metra wiring harness for me.
Old Oct 6, 2006 | 09:57 AM
bklusa1's Avatar
bklusa1
I do have the BOSE system, but does the metra harness run directly off RCA inputs? If that's the case then I wouldn't see a need for a line level converter because the signal would already be proper... correct?
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
