Better Battery?
Old Oct 14, 2006 | 07:41 AM
Dirty Dave's Avatar
Dirty Dave
Originally Posted by PumpedVA
yea you could flip it around but the cables will not reach still I need a adapter for the terminal
Send me your e mail address I had the same problem with my red top but I rewired it ( real easy ) and i'll send you a ppic of my setup if intrested.
Old Oct 14, 2006 | 10:48 AM
PumpedVA's Avatar
PumpedVA
pumpedva@yahoo.com
thanks bro
Old Oct 15, 2006 | 02:54 PM
Mathys's Avatar
Mathys
As stated before, the Optima Red Top 35 should be a direct swap without any modifcations needed. I think the Yellow Top 35 can be purchased with switched poles, which makes it more suitable for the 350Z. However, you might still have the issue with the cables being too short.
Old Dec 1, 2006 | 01:10 PM
JasonZ-YA's Avatar
JasonZ-YA
where is the best place to buy the replacement red top battery? cost?!? etc. thanks,
Jason!
Old Dec 22, 2006 | 04:37 AM
Altimate_Dream's Avatar
Altimate_Dream
If you have costco in your area. They have the red top 35. Im going to pick up one today probably. As for the yellow tops. Optima does have a yellow top D35R model. Its reverse terminal as we need. But, looks like it is only avail overseas for whatever reason. Id say just stick with the red top. Also, the Optima D51R Yellow would probably fit but, the CCA and CA is closer to stock. Just some suggestions.
Old Dec 22, 2006 | 05:05 AM
350zspl's Avatar
350zspl
take a look at stinger yellow series & red series
take a look at kinetic purples
both companies i am pretty sure have the side mounts and top post together
something in there line might be what your looking for
and have the post were you need and the cables might reach
these are high end batteries
Old Dec 22, 2006 | 06:29 AM
leemik's Avatar
leemik
Any Group 35 battery should work..
if you buy a different battery other than Group 35 you will need the reverse terminal version or you will need to extend your (+) battery cable.
I had an Optima yellow top D51R - Died within a year.. It is a lightweight reverse terminal direct replacement with no other mods to make it fit... i totally drained it one day by installing my Sirius radio module incorrectly and it never recovered. So much for deep cycle.
Then, I replaced it with a Optima Red Top 34R - Died within a year.. This battery is too short by about 1".. you'll need a piece of wood under it to be able to tie it down.. The car sat for 1 month in Oct and it totally drained.. since then.. battery has been acting "funny".. so with the onset of winter and remembering what happened to the yellow top.. I bought a Sears Diehard Group 35.. i'm through with Optimas lol
--mike
Old Dec 26, 2006 | 01:50 AM
Mark Basford's Avatar
Mark Basford
Try a grounding kit, I reckon it keeps the battery in good condition longer.....
Old Jan 11, 2007 | 06:59 PM
Fear Night's Avatar
Fear Night
Just wanted to add that the D35 Yellow top was a direct swap for me. There were no modifications needed whatsoever (besides the base that comes with all batteries from Optima). I was reading on here that there were people needing negative terminal shims or longer cables for use with other yellow tops. Not the D35!
Got mine from:
http://www.1st-optima-batteries.com/
Old Jan 11, 2007 | 09:44 PM
bay350z's Avatar
bay350z
I would get yellowtop and make it fit cause its awsome. Just never kill a deepcylce battery super low. Tweeter did that in my tiburon and good thing the battery was under warrenty still cause running it that low killed it. But optima are the best.
Old Jan 12, 2007 | 04:42 AM
HyperSprite's Avatar
HyperSprite
Mad Scientist
I got a D35, when I tightened down the negative, I could still twist it off. I replaced it with a 10" cable. Others have said wrap a piece of wire around the post.
Chris
Old Jan 12, 2007 | 06:06 AM
leemik's Avatar
leemik
Chris
same thing happened to me.. I just gave it a squeeze with a pair of heavy duty pliers to bend it slightly and it's snug as a bug now
--mike
Old Jan 12, 2007 | 06:14 AM
Jay'Z's Avatar
Jay'Z
Will I have this prob with the R34? Leemik, I cant believe you went through so many optima batterys...... I had a yellow top on my old Eclipse T but never had any probs and I ran a high power sucking MTX system.. I have had my stock battery almost two years now with no probs.. I must say maybe it has to do with the grounding kit I bought from japan. I just bought a redtop optima and cant wait to install today or tomorrow sometime..
Old Jan 12, 2007 | 06:24 AM
bay350z's Avatar
bay350z
You could go with a Gel battery espeically in a hot place. Where i live it gets to 120 in the summer and it kills batterys. And I think Gel is lighter too.
Old Jan 12, 2007 | 06:25 AM
leemik's Avatar
leemik
Yes, you will most likely have this problem with the R34 too.. not only that but you may have to put a piece of wood under your battery or it will not clamp down.. (battery too short)
I went through so many Optimas because I have a very small drain (probably from the CarPC) even when the car is off and my Z sits for weeks and weeks at a time in an unheated garage during the winter.. Optimas are supposed to recover aka deep cycle.. but my experience.. and my friends experience with Optimas have been similar.. they are not recovering as advertised..
--mike
Old Jan 12, 2007 | 06:27 AM
bay350z's Avatar
bay350z
Well they won't recover if you kill them too much.
What psu where you using on the carpc? Most of them protect you from that.
Old Jan 12, 2007 | 06:30 AM
Jay'Z's Avatar
Jay'Z
Aw ****!! Its too late, I already got my optima leemik, but oh well, are you telling me even with the red adaptor plate the optima comes with, it will still be short???
Old Jan 12, 2007 | 06:34 AM
  #38
leemik's Avatar
leemik
OPUS
Old Jan 12, 2007 | 06:42 AM
  #39
bay350z's Avatar
bay350z
Hmm that shouldn't of happen unless you where using standby. I have had both the m1 and m2 and the dsatx all been fine.
Old Jan 12, 2007 | 06:50 AM
  #40
leemik's Avatar
leemik
I was using standby.. that's what killed my stock battery.. shut that off.. but after that incident, battery would not charge period lol replaced it with a yellow top
then i screwed up my Sirus radio install and drained my yellow top one day a year later.. battery never recovered as it should have.. Battery would not hold a charge for more than 24 hours..
so i put in a red top last year.. that died last month.. i think the carPC is still drawing a teeny bit of current.. Battery would not hold a charge for more than 3 days..
so much for 1000 deep cycles or what ever they are rated for..
I now have a Sears Diehard lets see how long that lasts
--mike
