what's the best sealed volume, max or min?
Old Oct 30, 2006 | 06:58 AM
first350's Avatar
first350
Default what's the best sealed volume, max or min?
I have a Kicker solobaric 10" L5 that I'll be creating a sealed enclosure for...Kicker rec'd between 0.66 to 1.0 ft^3 of volume for the sealed enclosure.
what's the optimum volume I should aim for? (I'm making my own box, and won't have a problem getting that volume...is the max volume always better?)
thanks,
Peter
Old Oct 30, 2006 | 07:11 AM
TheCajunStyle's Avatar
TheCajunStyle
opt for 0.83 ft^3
Old Oct 30, 2006 | 07:16 AM
sq40's Avatar
sq40
I always hate it when a Company does not give you the Optimal Sealed Volume for their Driver.
I Would go with the Middle of the Road,
Old Oct 30, 2006 | 07:43 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
the L7 drives i honstly feel is best with the largest sealed volumes...
IMO, i usualy try to go for the biggest enclosure i can do under the recommendations, the gain in efficiency and really low bass is why...
b
Old Oct 30, 2006 | 08:23 AM
JimRHIT's Avatar
JimRHIT
If you like techno-punchy bass ... go smaller sealed.
If you like rap, country, or bass "test" music ... go for the bigger one.
Look at it this way .. you can make the box 1.0cf and if it isn't punchy enough, you can add wood blocks until you get it how you like it. It's much easier to subtract volume than to add it
Old Oct 30, 2006 | 09:59 AM
first350's Avatar
first350
b
I have an L5, would that make a difference?
thanks for the all the repsones!
-Peter
Old Oct 30, 2006 | 11:05 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
So sorry. Kicker doesn't publish their Qts specifications for their speakers for some unknown reason. The rest of the Thiel-Small parameters are there but I couldn't find the Qts and without it you can only guess. Each speaker will sound different - vasty so - in a different size volume. Austrailian acoustical scientist Thiel and Small figured out what driver parameters were needed to produce a certain response curve. Depending on what/how you like your music you size the box to match. After doing it once right you know what you like - I like a Qtc about 1.0 or a bit higher.
Knowing that I ran a series of speakers - most manufactures publish the required specifications and then took a listen to that narrower band of speakers.
Old Oct 30, 2006 | 12:19 PM
JimRHIT's Avatar
JimRHIT
S10L5 - Qts: 0.407 Vas -43L Fs -33Hz
Port that thing in 1.6cf @33Hz That'll be fun.
For sealed, I'd do ~1.0-1.25cf.
350Z_Al
Oct 29, 2020 07:44 PM
350z82
Oct 1, 2015 06:25 PM
