Dash Removal on 06 Model
Old Nov 4, 2006 | 08:03 PM
Stability's Avatar
Stability
Default Dash Removal on 06 Model
Has anyone done this yet. I searched but Only seem to come up with 2003. The cubby is different and doesnt have the same door clasp to remove. Any info would be helpfull.
Old Nov 4, 2006 | 08:05 PM
zman1910's Avatar
zman1910
Its essentially the same thing. I've had both models...and have taken apart both. Just the other day I put in the Avic Z1 and I asssure you its the same
Old Nov 4, 2006 | 08:25 PM
Stability's Avatar
Stability
how do you access the screws in the cubby?
Old Nov 4, 2006 | 08:27 PM
zman1910's Avatar
zman1910
There are 2 plastic covers on the sides(after you remove the rubber) that snap off with a screw driver....the screws are behind them
Old Nov 4, 2006 | 08:31 PM
Stability's Avatar
Stability
okay, i did see those, just didnt know if they were removable. Thank you for the help
Old Nov 4, 2006 | 08:59 PM
bdahern's Avatar
bdahern
I took mine out to install a Roady XT into the cubby - it is essentially the same as previous years - once you pull the rubber cover out of the cubby you will see what you need to do.
Old Nov 5, 2006 | 03:08 PM
bdahern's Avatar
bdahern
I took mine out again today while installing an amp/sub - the difference with the cubby is there are two plastic covers over the screws in the cubby that you need to remove - otherwise it is the same.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
350z82
Oct 1, 2015 06:25 PM
Depravity
Oct 1, 2015 04:49 PM
