Those who are running Alpine Type R's
Old Nov 6, 2006 | 10:44 AM
freemanjc's Avatar
freemanjc
Default Those who are running Alpine Type R's
Please tell what is the best amp to run these subs. I purchased a Hifonics amp to run these and they sound like doo doo! Took it to the local shop and he told me the amp is dirty and something about dampening has lost control of the the cone. I know the guy personally that runs the shop and he was not trying to sell me anything either. I was interested in buying a JL 250/1 but was wondering if the Alpine 605 would work.
Please help a brother out!
R,
Free
Old Nov 6, 2006 | 11:30 AM
classic6's Avatar
classic6
I am running the Alpine 605 for the 2 10'' type R's and I really like the sound. Great Amp, no issues at all.
Old Nov 6, 2006 | 11:59 AM
freemanjc's Avatar
freemanjc
Classic 6, I was told that that amp would not work on the Dual 4 ohms Type-R 10" Subwoofer . Are they lying to me?
R,
Julius
Old Nov 6, 2006 | 12:16 PM
classic6's Avatar
classic6
What ohm and how many type R's are you running?
Old Nov 6, 2006 | 12:38 PM
freemanjc's Avatar
freemanjc
I am running 2 Alpine SWR-1042D - Alpine 10" Type R 1500W Dual 4 Ohm Subwoofer off a weak Hifonisc 1206 D amp that is dirty power. I should have known better?
Old Nov 6, 2006 | 12:56 PM
freemanjc's Avatar
freemanjc
are your type r's 2 ohm or dual 4 ohm
classic6's Avatar
classic6
ok. Your friend is correct. If your subs were two ohm then the 605 would work great if you ran them in parrel. If you want the 605, you would be better off just running 1 of those subs. That amp with those two subs would only produce half the power.
Old Nov 6, 2006 | 01:21 PM
colds14's Avatar
colds14
Here are some options:
-2 mrdm605s, one for each sub.
-1 Alpine pdx 11000. Wire the subs so they see a 4ohm load and youll have 1000rms going to them.
-JL 500/1. You would be underdriving them slightly, but would have a high dampening factor(better control).
There are hundreads of other choices but I only wanted to mention what you have alreaady stated for brands.
Old Nov 6, 2006 | 02:38 PM
freemanjc's Avatar
freemanjc
Cold 14
As far as the MRD amps you suggested above is it this one
http://www.crutchfield.com/S-fdYdipi...0&I=500MRPM650
or this one
http://www.crutchfield.com/S-fdYdipi...0&I=500MRDM605
Thanks, I figure if I run one of these amp to each sub, I am running it in a 2ohm load or 4 ohm load?
Old Nov 6, 2006 | 02:43 PM
colds14's Avatar
colds14
Either of those will work. The second one will give you more control as its a
v12 series. As long as each sub is wired in parrallel then you will be at 2 ohms each.
Old Nov 6, 2006 | 03:02 PM
freemanjc's Avatar
freemanjc
Thanks Cold 14
I am also interested in the Elemental Design Nine.1 too.
Old Nov 6, 2006 | 05:02 PM
freemanjc's Avatar
freemanjc
If I buy one for each sub Will I be running in a 4 ohm load or a 2 ohm load with two Alpine type that are DVC 4 ohm.
Old Nov 6, 2006 | 07:06 PM
colds14's Avatar
colds14
I don't know much about E.D. amps but by the specs Lots of power for a little amp. The only thing that worries me is the dampining factor is only 300. But it is a sub amp.
As for what ohm level....One dual 4 ohm sub wired in parallell will be at 2 ohms.
Old Nov 13, 2006 | 08:09 PM
manny G's Avatar
manny G
My speakers are coming in tomorrow i got 2 ten type R's off of www.onlinecarstereo.com they have great prices and i am also about to buy the new alpine 1000 to 1 amp off the same site. my box is coming in three days from now it is a custom fit to go under my strut bar Go to google and type in 350z subwoofer box and ebay will show up like the third site down it is called Zenclosers take a look at them they are awsome.
apex locator
Jul 23, 2021 02:27 AM
dcains
Nov 11, 2015 11:36 PM
