dynamat worth the time and effort
Old Mar 19, 2003 | 03:52 AM
oogybgy's Avatar
oogybgy
Default dynamat worth the time and effort
I have read about some people using dynamat when installing subs. Is this really necessary? I am thinking about getting a JL 10W3v2, and want good low bass, but nothing outrageous. I really do not want to go to the trouble of using a sound-deadening material if it isn't absolutely necessary. I have noticed that most people do not mention having this with aftermarket installs, which leads me to believe it isn't THAT necessary. any thoughts?
Old Mar 19, 2003 | 04:05 PM
LS350Z's Avatar
LS350Z
Charter Member #56
Well if you'd like to minimize dynamat useage then start with zero and add as you find rattles/vibrations.
I've got a single 10" Boston Pro and I'm now 6 sheets deep of dynamat. I started with 3 sheets and have been adding ever since trying to minimize rattles/vibrations. I still need at least one more sheet.
Old Mar 20, 2003 | 03:16 AM
tonkadog's Avatar
tonkadog
thanks for the info,
I know all cars will be different, but where are you finding most of your rattles/vibrations? We are actually thinking of doing the install and adding if needed. Figured the trunk would be the starting point.
Old Mar 20, 2003 | 04:32 AM
LS350Z's Avatar
LS350Z
Charter Member #56
Most of my troublesome rattles have been in the trunk especially around the b-c pillar window. Except for the excessive vibrations in the door panels I've had no real rattles up front.
I was actually wrong earlier, I've used 7 sheets of dynamat in the car (2 per door and 3 in the trunk).
Obadabot
Jun 18, 2023 11:31 PM
