Say what?!?!
Old Dec 25, 2006 | 08:37 PM
MFAnello350's Avatar
MFAnello350
Default Say what?!?!
Hey guys,
i did a search and i couldnt find the answer i'm looking for....If i install a aftermarket headunit ex. Alpine 310 7in flip out...Would i need to change my whole setup, speakers and all?...supposely the guy the local shop said i had to change all my speakers and whatnot if i just change my headunit...btw...i have the bose WITHOUT the navigation setup...
can someone help me out....thanks....
Old Dec 25, 2006 | 09:04 PM
Endless Shock's Avatar
Endless Shock
I dont see why you need to change your speakes out... I dont have a bose system so I could be wrong...
Old Dec 25, 2006 | 09:07 PM
xalos1's Avatar
xalos1
Check this out...
Go to 350z - tech . com and go to audio and video... there is alot of great information.
Old Dec 25, 2006 | 09:08 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
You don't need to change your speakers but it is ideal when you get a nice head unit to exploit the quailty of the new deck. Like all audio systems in a car or home, your system is only as good as your weakest link between the source (receiver or HU), connections (cables) and your output (speakers)
Old Dec 26, 2006 | 08:26 AM
MFAnello350
Is this true....esp. about bypassing the Bose Amp?...anyone who has expierence wit this?...i think this is nuts...but this is why im asking for help...btw...350zTech really didnt say much abou the subject...
Old Dec 26, 2006 | 09:45 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
When I was a kid I was a car stereo installer ... then I spend two dozen years as a television studio engineer, chief engineer, and then a project manager for a satellite television broadcast facility. Upon my retirement I bought the Z and started playing with it.
I changed out the subwoofer in the stock position - deeper cleaner base but no where enough base. I ended up with an amplifier, a Zenclosure, and a pair of 10" woofers.
Then I installed a Pionner AVIC N2 and changed out the front speakers. I had to bypass the Bose four channel amplifier to allow the Pioneer drive the speakers directly. Much much better. The 22 watts of the headend drove the front speakers to a level loud enough for most.
Bypassing the Bose amplifier was temporary as I later ran my own wires. Here's a chart I made to aid me in connecting the wires up.
I just connected the line-level cables to the speaker level wires and then connected the Pioneer to the old line-level wires and drove the speakers directly by-passing the Bose amp.
So why by-pass the Bose amplifier? The subwoofer amplifier might be good for 8-12 watts being generous.
The four channel amplifer is probably rated about the same wattage. I have no idea how Nissan or Bose came up with the wattage they claim. I opened the four channel amplifier open to see what the output transistors were and cross them to see what their outputs really were. I come to find out that there are no output power transistors - just little IC chips.
Old Dec 26, 2006 | 02:46 PM
Spike100's Avatar
Spike100
Hi Paul,
All I can say is just another great posting! Thanks for the information and great pics.
Old Dec 26, 2006 | 04:19 PM
MR_X's Avatar
MR_X
same thing I was going to say, bypass the bose amp. The "easiest" way to do it is to run new wires to the speakers. That way you are not cutting wires in case you want to trade/sale the car in the future.
Old Dec 26, 2006 | 04:48 PM
MFAnello350
thanks guys
Old Dec 26, 2006 | 07:30 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Stone him ... he's a witch!
Old Dec 26, 2006 | 07:40 PM
MFAnello350
real quick....where is the stock Bose Amp?
Old Dec 27, 2006 | 06:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
There are two.
The subwoofer amplifier is located inboard toward the centerline from the subwoofer itself mounted right next to it.
The four channel amplifier is located on the driver's side in the trunk right below the antenna.
Old Dec 27, 2006 | 05:45 PM
MFAnello350
if i just get the head unit and the Ipod hook up wire....would the installer still have to cut the wire to the Bose amp? i really dont know much about this...sorry if i sound silly asking weird questions....
