nav audio louder with aftermarket HU?
Old Mar 28, 2003 | 01:12 PM
Quick's Avatar
Quick
Default nav audio louder with aftermarket HU?
Okay, i have an alipine 7897 installed with a mute circuit wired up as well (thanks onecoolee). Everything works great except that the nav audio could be a little louder. I have the volume cranked up all the way on the nav voice, and the speaker is behind the dash on the drivers side. I was trying to find an inline amplifier and CC had one, but it only drives an 8ohm speaker. I am currently using an infiniti 3.5 which is a 4ohm.
So, any other ideas?
Old Mar 29, 2003 | 05:11 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
i used an amp'd center channel from kenwood... look here:
https://my350z.com/forum/showthread....center+channel
Old Mar 29, 2003 | 06:21 AM
z2thdr's Avatar
z2thdr
Question Volume
Quick...I also have the same problem with the Alpine 7897 HU and the Alpine NAV system. It is going back to the shop for the installation of a small external speaker with a volume control. Do you also have a buzzing sound when the NAV voice comes on? Is this part of the system or is it distortion?
Old Mar 29, 2003 | 06:54 AM
Mikey Likes It's Avatar
Mikey Likes It
Charter Member #44
I used an Alpine SBS-0715. It came with a 45W amp. I mounted in-between the seats and have no problem with the audio. The amp is very small and can go just about anywhere.
Mike
Old Apr 1, 2003 | 05:20 AM
Quick's Avatar
Quick
Default Re: Volume
well, i ended up changing my setup, again. This time i took the nav speaker from my old pioneer HU and mounted it behind my head on the trim panel. It is loud enough now, as well as fairly clear. I don't have any crackling noises at all. It doesn't sound as good as it did from the 3.5 inifiniti, but i figure what kind of sound can you expect from a 2" speaker anyway. I will try and get some pics of my system this weekend after my speaker install..
apex locator
Jul 23, 2021 02:27 AM
JGee450
Sep 30, 2015 04:32 AM
SharX59
Sep 27, 2015 09:23 AM
Extreme Dimensions
Southern California
Sep 24, 2015 03:35 PM
