Wiring kit question
Old Jan 14, 2007 | 01:37 PM
emtae's Avatar
emtae
Default Wiring kit question
OK I have done some reading but I still have a few questions. First the hardware. Pioneer AVH-P6800DVD HU and Pioneer PRS-D4000F Amp. 600 watts. I am looking at the Stinger SWKH8RS wiring kit.
1) Is that a good kit or is there another I should look at?
2)It doesn't appear to have a power distribution block with it. Do I need one?
3)Do I need one of these? a http://item.express.ebay.com/Consume...mdZExpressItem
4) Do I need a wiring harness for the Pioneer AVH ? If so the Metra ?
I don't think I am going to wire it myself I just want to have everything I need before I take it to the shop so I don't have to pay their jacked up prices. Am I missing anything?
This price on the Stinger looks good
http://cgi.ebay.com/STINGER-SWKH8RS-...QQcmdZViewItem
Old Jan 14, 2007 | 03:17 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
8 gauge wire will work for the 600 watt Pioneer amplifier
Nope, as long as you've only got one amplifier.
Nope. There's a spare post on the 350Z. You will need a properly sized ring terminal for 8 gauge wire. It looks like the Stinger wiring kit comes with one.
4) Do I need a wiring harness for the Alpine AVH ?
What's an Alpine AVH? Pioneer makes AVH-P5700x DVD monitors is this what you're asking? No monitor that will fit inside a 350Z needs a heavy gauge cable - will it need some sort of wiring? Yes.
If so the Metra ?
Answers in red above.
Old Jan 14, 2007 | 03:44 PM
emtae's Avatar
emtae
Thanks. Yes I mean the Pioneer AVH.This is what I mean by the Metra wiring harness. Is it needed or only req'd if I am using my stock sound system wiring ?
http://www.circuitcity.com/ccd/produ...&c=1&oid=41031
Old Jan 14, 2007 | 07:03 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
It's always best to use an adapter cable for your headend into the factory harness unless you plan on blowing away the factory speakers and amplifiers - which itself is a good idea too! You'll be by-passing the wiring for the amplified speakers at a minimum but could use the harness for the power wires.
One way or another you need some sort of plug and jack arrangement to make installation and maintenance later easier. Many manufacturers provide a matching jack to their headend's plug. That jack can be spliced into the factory harness.
bcoffee20
Nov 19, 2015 06:39 PM
SpartanZ32
Oct 22, 2015 09:36 AM
Mattg350z
Oct 2, 2015 06:51 AM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
