BOSE hi level input to amp/sub
Old Feb 6, 2007 | 03:27 PM
tc2468's Avatar
tc2468
Default BOSE hi level input to amp/sub
For those of you who have tapped into the BOSE system using high level/speaker level inputs on their amps or basslink, where did you tap the wires?
1) subwoofer wires before the BOSE sub amp?
2) subwoofer wires after the BOSE sub amp?
3) rear speaker wires before the BOSE amp? left/right or both for 2 subs
4) rear speaker wires after the BOSE amp? left/right or both for 2 subs
5) front speakers before or after BOSE amp?
6) other
thanks
TC
Old Mar 31, 2007 | 04:37 PM
tricked04's Avatar
tricked04
bump to this, I would also like to know.
I just used the wires connecting the bose sub. But dont' know which one is negative and postive so I am researching that right now.
Old Apr 2, 2007 | 07:26 PM
tricked04's Avatar
tricked04
anyone running aftermarket sub & amp with stock bose?
Old May 8, 2007 | 09:48 AM
RedBullRR's Avatar
RedBullRR
BUMP need info to.
Old May 8, 2007 | 09:58 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
I'm not sure what you're asking - what are you trying to do? By tapping into your Bose system I'm guessing that you want to change the head end and still use the amplifier and speakers? If so feed the amp line level output and be done with it. The speakers are very poorly designed and the amplifier is teeny-tiny and wimpy.
If you're attempting to hook a Basslink they'll accept either line level or speaker level. In either case you're connecting them up to the Bose system which tweaks (distorts!) the signal to match (make up for the crappy quality) of their speakers. I would avoid doing this if at all possible ... but I would take the line level input into the subwoofer if I had to - yick.
Here's the Bose woofer next to another. Imagine the amount of processing that has to take place to make this speaker sound even half right?
m_0g
Jun 3, 2021 10:05 AM
sales@czp
Sep 23, 2019 03:30 PM
bcoffee20
Nov 19, 2015 06:39 PM
