Has anyone hardwired their radar detector??
Old Feb 9, 2007 | 06:05 PM
suv11186's Avatar
suv11186
Default Has anyone hardwired their radar detector??
I have a base '03 and the only cigarette lighter plug in is in the back of my seats in the middle section. Has anyone hardwired their radar detector in a way so that you dont have that rediculous cord hangin all the way through your cars **** pit area? If so, could you help a brother out on how you did yours? I have the wiring kit and the Passport 8500 X50. So, all I need is some help, if possible in this car, on how to do it. Any help would be much appreciated. Thanks fellas.
Old Feb 9, 2007 | 06:26 PM
DavesZ#3's Avatar
DavesZ#3
I recently hardwired my V1. It uses standard phone cord (the flat kind) which can easily be routed from the back hatch opening all the way to the front by the fuse panel without having to remove any panels, etc. I used a 1" putty knife to lift the edges of the plastic trim and force the wires under it. The putty knife can also be used to push the wire into and between trim pieces and the rubber seals.
Old Feb 9, 2007 | 07:35 PM
mthreat's Avatar
mthreat
Default invisicord
The answer is Invisicord.
Details Here
Old Feb 9, 2007 | 07:50 PM
UGOTZ'D's Avatar
UGOTZ'D
i have my detector right at my a pillar by my sunvisor and ran the wire down the a-pilar into the fuse box. took about an hour to install
Old Feb 9, 2007 | 07:58 PM
jamaicanj's Avatar
jamaicanj
Default invisicord
the invisicord is fantastic. shipping took 4 days after ordering and it took me about 10-15 minutes to set it up.
Old Feb 10, 2007 | 03:02 AM
Barzten1's Avatar
Barzten1
I had my local stereo shop hardwire mine into my rearview mirror.
Old Feb 10, 2007 | 03:18 AM
suv11186's Avatar
suv11186
Where into the fuse box did you connect the power and ground into and does your radar detector turn on when you turn your car on and off when you turn it off?
Old Feb 10, 2007 | 03:08 PM
TurboTrey's Avatar
TurboTrey
If your radar detector uses a regular power plug you can just chop the end off and stick in into the back of the rear view mirror if you have the home link or auto dimming mirror. You'l have to look around here to find out which spots to plug it in to. I did this and just used male prong connectors and chopped off one side and stuck it in there.
Old Feb 10, 2007 | 06:04 PM
mthreat's Avatar
mthreat
This is what the invisicord does, without any chopping, and it has instructions and pictures showing which color wires to tap into the rearview mirror plug.
Old Feb 11, 2007 | 06:50 PM
TurboTrey's Avatar
TurboTrey
I actually followed the invisicord instructions and just cut the end of my original power cord off (my beltronics came with 2, a twisted and a straight).
Old Feb 13, 2007 | 11:44 AM
cellude's Avatar
cellude
Has anyone installed the InvisiCord on a base (w/out homelink mirror)? Someone mentioned in a past post that the Base still has the connections for the homelink mirror stashed away. True?
Old Feb 13, 2007 | 12:37 PM
Lsmith9523's Avatar
Lsmith9523
Originally Posted by cellude
Has anyone installed the InvisiCord on a base (w/out homelink mirror)? Someone mentioned in a past post that the Base still has the connections for the homelike mirror stashed away. True?
I would like to know the answer to this as well^......although, I did my hardwire, under the roof line,,,down the pass side pillow and to the cig lighter on pass side..06 here...
Still curious...........
Old Feb 13, 2007 | 02:38 PM
DavesZ#3's Avatar
DavesZ#3
I suspect if you remove the Interior Room Lamps from the overhead console, you'll find the wiring for the rearview mirror running there. That's where the wiring appears to come out from the roof on our Zs.
Old Feb 13, 2007 | 02:53 PM
stereoneeds's Avatar
stereoneeds
what are you guys using to mount the radar detector to your mirror?
Old Feb 13, 2007 | 04:45 PM
TurboTrey's Avatar
TurboTrey
Mine came with a clip. I've seen others use hangers to mount it directly to the rear view mirror. Only bad thing about mine is you can't lower the passenger vanity mirror down with it up there.
Old Feb 13, 2007 | 05:14 PM
Lsmith9523's Avatar
Lsmith9523
Honestly, I have the beltronics Pro RX 65. I am using the suction cup bracket....I have it hardwired as, said in my above post. I have seen the rearview hangers here that look awesome. I will upgrade to one of the mirror hangers soon....
Old Feb 15, 2007 | 08:45 AM
stereoneeds
yeah i just ordered the z bracket from mike. cant wait
Old Feb 17, 2007 | 04:13 PM
MIKE3348's Avatar
MIKE3348
stereoneeds,
Here is a picture of what my mount looks like. It clamps to the mirror shaft and uses th original suction cup bracket less suction cups.
PM me for details. I have sold alot to forum members.
mike3348 (maker of mikes mount)
Old Feb 21, 2007 | 01:45 PM
stereoneeds
just got the invisicord for $12 and got the bracket from mike. install tool all of 30 seconds. now that i have this setup i wonder how i dealt with those suction cups for so long thanks mike!
Old Feb 21, 2007 | 03:46 PM
MIKE3348's Avatar
MIKE3348
stereoneeds,
Your welcome!! Glad you like my mount!!!
mike3348
