hooking up two 10" to one amp
Old Mar 7, 2007 | 07:46 PM
Praz's Avatar
Praz
Default hooking up two 10" to one amp
alright i dont know too much about sound stuff but i have a question on hooking up subs. the subs are pioneer 10" ones and are the dual voice coil ones. if i want to hook up two to a mono sub amp, can this be done? if so how?
Old Mar 8, 2007 | 03:48 AM
StreetOC192's Avatar
StreetOC192
What ohm are each voice coil and what ohm is your amp stable down to?
Old Mar 8, 2007 | 04:22 AM
Lsmith9523's Avatar
Lsmith9523
As StreetOC192 said above,,, depending on the ohm of voice coils and what Ohm your amp is stable down to,,,will be the deciding factor to best utilitze your equipment soundwise/power load. Let us know what you have.....
Old Mar 8, 2007 | 05:30 AM
dmroberson's Avatar
dmroberson
It can be done, but you need to look at what was said above, to use your system most efficiently
Old Mar 8, 2007 | 05:37 AM
teh215's Avatar
teh215
Go here and do some reading under subwoofers and then amplifiers.
http://www.crutchfieldadvisor.com/S-...ingcenter/car/
Old Mar 8, 2007 | 05:46 AM
h8bumps's Avatar
h8bumps
If the subs are dual 4 ohm voice coils, hook the voice coils up in series, then hook the two subs up to the amp in parallel. This will result in a 4 ohm mono load for the amp.
Old Mar 8, 2007 | 11:32 AM
702Fairlady's Avatar
702Fairlady
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp
Old Mar 8, 2007 | 08:36 PM
Praz's Avatar
Praz
here is a link to the amp and subwoofer. again i dont really understand about dual voice coil
and http://www.pioneerelectronics.com/pn...262758,00.html
Old Mar 9, 2007 | 03:44 AM
StreetOC192
OK, that amp is 2ohm stable. You really need to know if your subs are the TS-W257D2 or TS-W257D2D4 to know how much power you will get from your amp. You will be wiring them the same way though either way.
D2 = dual 2 ohm voice coil
D4 = dual 4 ohm voice coil
If they are the TS-W257D2:
This diagram will yield you 360 watts to the subs.
If they are the TS-W257D4:
This diagram will yield you 250 watts to the subs.
m_0g
Jun 3, 2021 10:05 AM
BEBO'S ZEE
Jun 7, 2016 07:48 AM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
