Is 4 Gauge Enough and Where to Place Crossovers?
on
Two questions for those in the know:
1) This weekend I plan to replace my two current amps with a JL 300/2 and and JL 500/1. My question is, I currently have a single 4 gauge run to a distribution block wihch splits it out into two 8 gauge runs. Would these be sufficient to run the new JL amps?
I'm considering running a new single 2 gauge length and splitting it out into two 4 gauges but am wondering if this is necessary...
2) I am also replacing my current component set with a new set from Infinity. My previous set had the crossovers mounted low in the doors however the instructions in the new set advise against a door mount as the crossovers are not weather proof. Suggestions?
Thanks...
Thanks...
on
1 - your current guages are fine for your new setup, just keep the 8 awg runs short (under 3 foot each).
2 - i don't like the xovers in the doors myself. not easy access, not weatherproof, etc.
on
First, you might as well run all 8 guage, because once you go to a smaller wire you limit your current. Even with the 4 guage lead, the current drops after the dist. block. I would go with atleast 4 all the way back.
Thanks...
Thanks...
4 awg is fine for what your planning
though i did and would do 0 awg in case you ever want to get larger amps
and woofers that handle more power
i put my crossovers in my glove box
mine are quite large
9" l x 4 " w x 1.5" h
on
on
If I end up doing another run, I'll go ahead and go with 2 or 0 awg. It looks like I'm going to give the 4/8 solution a try for now. If I have any issues, it'll be a good excuse for an upgrade
you will be fine
i am always changing stuff around so i leave my options open
cool
on
About a 1/4 of the way down this page: http://www.bcae1.com/wire.htm shows that over a 15 foot run, 4awg will show only a 1/2 volt drop up to 131 amps. I believe it should be determined by the amp ratings of the amplifiers used. Some class amps are more efficient than others.
To the OP: Add up the fuse ratings of all of your amplifiers and refer to the chart on the page I linked above.
on
The fuse ratings for my amps are as follows:
JL 300/2 - 40amp
JL 500/1 - 50amp
Based on the charts listed by the link you provided, my 4awg run split into two 8awg runs should be sufficient.
11-09-2020 10:27 AM
