best way to connect speaker wires?
Old Mar 17, 2007 | 10:39 AM
dtak59's Avatar
dtak59
Default best way to connect speaker wires?
As the title states, what is the best way to connect two pieces of speaker wires, while maintaining the highest level of quality? I know the best would probably be to solder the wires, however, I am there are too many wires for me to even consider soldering.
Here's my situation...When installing my stereo, I had the shop bi-amp the components and I requested that they mount the crossovers close to the amp with excess wire so that in the future, I may run the components fully active. However, the crossovers were mounted in the kick panels. Now I am stuck trying to figure out how I will connect 8 pairs of wires.
All wire manufacturers swear by OFC, silver, gold, wire pattern, etc. Is there something better than some crappy butt-connectors or quick-connectors that I can use? Thanks for all your help.
Old Mar 17, 2007 | 10:47 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i will say this, if you just any type of solid metal to metal contact connects, you wont be noticing ANY drop in SQ within the speaker wires.
i use quick disconnects to make the major connections on all my speaker wires...bullet type male/female is good. spade is fine as well but need to get isulated. this makes for easy diagnosis and trouble shoot if a problem arisess.
b
Old Mar 17, 2007 | 11:15 AM
Ichigo's Avatar
Ichigo
http://item.express.ebay.com/Blue-Fe...mdZExpressItem
http://item.express.ebay.com/Blue-Ma...mdZExpressItem
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
