View Poll Results: One 10 or Two?
one
57
52.29%
two
52
47.71%
Voters: 109. You may not vote on this poll
Zenclosures 1 or 2 tens? is 2 too much?
Old Mar 27, 2007 | 12:36 PM
z2envy's Avatar
z2envy
I have 2 10's and no issues. But I'm not using a Zenclosure. Had mine custom made. The sound is amazing.
Old Mar 27, 2007 | 12:40 PM
Fluid1's Avatar
Fluid1
Originally Posted by HondaKiller
i run two kicker comps in a Z enclosure. I have a kicker amp so it helps with the lack of air space (sounds clear) but i can tell the subs have problems picking up the low notes. I filled the majority of the box with cotten to help even out for the lack of air space. It helped dramatically, but it didtn work miracles. They will sound good, but not like the maxima with a bigger trunk and box.
I put a sub behind the seat also, so that makes 3 10s for me. Depending on your taste it can become overwhelming, so i installed a JL Audio bass **** which will adjust the bass to all different levels. (from off to all the way up) It is like an upgraded cross-over and works beautifully.
Are the two subs in separate chambers? If not, nothing you say should hold any water, as you don't know the basics of audio. If they are, then I withdraw my comment.
Fluid1's Avatar
Fluid1
Same as above....are they in separate chambers?
Old Mar 27, 2007 | 12:57 PM
2fast4thelaw's Avatar
2fast4thelaw
Forget the (2) 10's, there isn't enough airspace in those boxes to get really deep bass. You can get a single 12" under the strut bar. You will have way deeper bass, move about same if not more air and drop your install cost in half.
This box is custom made by xtremekustoms on ebay. You will have to do a search since he doesen't post them on ebay anymore due to demand. I bought one from him a few months ago and its a damn nice enclosure. It has about 1.25 cu ft of internal space.
I have a JL Audio 12W3V3 in it and it sounds awesome! It sounds way better than the single Alpine Type-R 10 I had in there and it was no slouch! The JL 12 is twice as loud, twice as deep, and hits twice as hard!
Old Mar 27, 2007 | 04:03 PM
pyropete's Avatar
pyropete
The Zenclosure box is seperate chambers. Or atleast that is what he lists. Mine hasn't arrvied yet (due today) so I haven't seen it first hand.. I hope that it is seperate though? Why wouldn't it be?
Old Mar 27, 2007 | 06:54 PM
doug's Avatar
doug
you have the nerve to talk about deep bass and using a single 12 and then say you are using a JL 12w3 ?
i know 10" Brahmas, 10" ID Max and 10" RE that will hit harder than 2 12w3
Old Mar 27, 2007 | 07:00 PM
*ZYAL8R*'s Avatar
*ZYAL8R*
I have a 12w7 and was wondering if the box could fit it or one be made to fit it?
Old Mar 29, 2007 | 07:30 PM
Mesto's Avatar
Mesto
You should get 1 10'' RE SX
Old Apr 5, 2007 | 01:10 PM
2fast4thelaw
Well, yeah! I am only running 250 watts rms. That isnt going to make a brama or an idmax even move! But, consider what a 12" brahma or IDmax 12would do over the 10" version. Plus those subs are in whole other class than JL w3. I bought a w3 because its efficient and will make the best of the 250 watts my JL amp puts out.
Old Apr 5, 2007 | 03:30 PM
doug's Avatar
doug
ok ..
Old Apr 5, 2007 | 07:29 PM
cz3ch's Avatar
cz3ch
Originally Posted by Faikius
I voted 1.
I went from 2 Image Dynamics IDQ10's to a single JL Audio 10W7. I'm much happier with the W7.
It seems to hit quite a bit harder and louder than the 2 IDQ's.
To be fair though, I also changed amps...
I'm also going to run a 10W7 and a JL-500/1 to power it.. Should slam pretty hard in the z-enclosure..
I'd say go with one... these are sport cars... i like to keep it subtle and very clean.. one sub, one amp, both aesthetically pleasing = good stuff!
Old Apr 14, 2007 | 03:25 PM
SS21CA's Avatar
SS21CA
Generally speaking, you can probably have a good setup w/ 2 10's at .8-1.1 ft box. If you want to only have 1 sub but a lot of power look into Image Dynamics IDMAX10, JL, Adire.
If you get 2 subs in the sealed enclosure but feel it's not hitting low enough. you can buy polyfill from fabric stores, walmart etc.. Similar concept to the cotton suggestion i suppose (never heard of using cotton b4).
Keep in mind 1 12" sub will be just as strong as 2 10's. It will most likely hit a lot lower too.
I personally have 2 Image Dynamics 10" subs. 800w RMS feeding them..
Old Jun 28, 2007 | 09:54 PM
johnnybravo26's Avatar
johnnybravo26
hey does the custom box for 2 10s have enough air space for 2 10w6v2? can that box handle those subs? i'm talkin bout those custom boxes that you see all over ebay. thanks.
Old Jun 29, 2007 | 09:14 AM
RedBullRR's Avatar
RedBullRR
I have 1 with my stock HU, and its enough for my taste. I have the Bass Level all the way down to low, and it still hits hard. Sometimes I think the dam Glass is gonna break.
Old Jun 29, 2007 | 09:43 AM
soleil's Avatar
soleil
NolaZcc
i have the dual zen box with JL 10w3 and it hits hard
Old Jul 3, 2007 | 10:08 AM
gothchick's Avatar
gothchick
I have (1) 10" 200w Infinity Sub... Was thinking of adding a second one to the mix...
Old Jul 3, 2007 | 12:15 PM
topgear's Avatar
topgear
One 10W6V2 is all you need.
Old Jul 3, 2007 | 01:38 PM
  #38
alan86's Avatar
alan86
10w7, 500/1
Old Jul 4, 2007 | 12:00 PM
  #39
gothchick's Avatar
gothchick
Okay guys... I added a second 200w Infinity 10" basslink last night... It does hit harder now... But not night & day harder. It just "fills" the car more completely now without sounding strained... I'm trying to figure out a stealth capacitor mod for my next evolution of my sound system... Since I have 700w amp total now... 300w up front, and 400w in back.
These aren't glammer shots, but you get the jist... :-)
Attached Thumbnails Zenclosures 1 or 2 tens? is 2 too much?-dsc02010.jpg   Zenclosures 1 or 2 tens? is 2 too much?-dsc02007.jpg   Zenclosures 1 or 2 tens? is 2 too much?-dsc02008.jpg
Old Jul 4, 2007 | 12:09 PM
  #40
Seel's Avatar
Seel
Originally Posted by gothchick
Okay guys... I added a second 200w Infinity 10" bass link last night... It does hit harder now... But not night & day harder. It just "fills" the car more completely now without sounding strained... I'm trying to figure out a stealth capacitor mod for my next evolution of my sound system... Since I have 700w amp total now... 300w up front, and 400w in back.
Is there any particular reason you don't just use a Zenclosure for the subs?
