Passport 8500 directwire install
Old Apr 4, 2007 | 01:59 PM
dmroberson's Avatar
dmroberson
Default Passport 8500 directwire install
Ok, I just got the directwire kit for my Passport 8500 X50 radar detector.
Can anybody suggest the easiest way to install this? The install sheet is very generic... says black is ground, and the striped wire is the hot wire.
Ok, where is the best place to tap the ground/ hot lead into? I have no idea how to get this hooked up, and don't want to ruin the detector, or more importantly, the car.
Thanks.
Old Apr 4, 2007 | 02:14 PM
Peak350's Avatar
Peak350
Thanks.
I've read that you can just tap the power for the mirror, but I haven't bothered hardwiring mine yet.
Old Apr 4, 2007 | 02:21 PM
VIZAGE's Avatar
VIZAGE
How has the Passport worked for you in the past? I'm really going to jump on one soon.
Old Apr 4, 2007 | 02:31 PM
Peak350's Avatar
Peak350
If you're buying new get a V1, and a blinder.
There are two issues with the passport, it has less strength and takes longer to notify you on a received signal, and it doesn't hold value like a V1.
A blinder is essential for interstate speeding, highly funded departments give the motor's division laser guns to play with.
Old Apr 4, 2007 | 02:51 PM
MarkY's Avatar
MarkY
I have a V1, but what the hell is a blinder?
To the OP, I hardwired my V1 to my rear view mirror. Fairly simple IF you have the homelink mirror.
Old Apr 4, 2007 | 03:20 PM
XuperXero's Avatar
XuperXero
+1 on what's blinder
Old Apr 4, 2007 | 03:29 PM
zstreet86's Avatar
zstreet86
i ran i ran it all the way to the fuse panel in the drivers footwell and simply just plugged it into a slot that was hot when the key is on (test which one with a test light) and just undid one of the bolts down there and put it back with the ground wire underneath it. took 10 mins
Old Apr 4, 2007 | 03:41 PM
John Bronze's Avatar
John Bronze
a blinder is a laser jammer. http://www.radarbusters.com/products...er/default.asp
Old Apr 5, 2007 | 06:45 AM
dmroberson's Avatar
dmroberson
I like my Passport. Haven't had any problems with it. Bought it off of ebay for $200. I've read that the x50 is just as good as the V1, but just costs less, that's what fueled my choice.
So, nobody knows how to install the directwire kit?? I don't have the autodimming rearview so can't tap into the mirror.
Old Apr 5, 2007 | 06:46 AM
MarkY's Avatar
MarkY
Old Apr 5, 2007 | 06:48 AM
JDMFairladyZ33's Avatar
JDMFairladyZ33
Originally Posted by MarkY
Depending on the test, the V1 and X50 were pretty close.
Old Apr 5, 2007 | 09:22 AM
John Bronze
I hardwired mine to my radio, I ran the wires along the headliner, under the dash to the radio.
Old Apr 5, 2007 | 12:43 PM
dmroberson's Avatar
dmroberson
Ok, I'll check that out. Thanks.
Old Apr 5, 2007 | 12:48 PM
blasian's Avatar
blasian
I have an x50 and I've had plenty of time of knowing if I was getting radar or not...
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
