Looking for great subs with a shallow mount
Old Apr 6, 2007 | 05:59 AM
Gilley's Avatar
Gilley
Default Looking for great subs with a shallow mount
I want to build a concealed enclosure in the trunk of my G35 coupe that will allow stock functionality for daily use, but which will be a showpiece at car shows with the trunk mat removed. The problem is that the stock tire well depth is about 6 1/2 inches. I have a JL 10w6 and was planning on adding another, but their mounting depth is 6.9 inches, which doesn't account for the top of the speaker and room for excusion, or 3/4 inch of MDF at the bottom of the box.
So, I'm looking for alternatives with a shallower mounting depth and yet still have good output (similar to or better than the 10w6), if possible.
I'll be powering them with a JL 500/1.
Any ideas?
Old Apr 6, 2007 | 06:29 AM
doug's Avatar
doug
Image Dynamics IDQ
http://www.imagedynamicsusa.com/tech...ype=sub&id=idq
Resonant Engineering SR or RE modles
http://www.reaudio.com/specs.html
http://www.reaudio.com/woofers.html
Old Apr 6, 2007 | 06:33 AM
350zspl's Avatar
350zspl
Any ideas?
well i like the way the shallow mount RF P3 sound ,better than the w6 that don't fit in your plan anyway
they handle like 500 rms or a bit more
Description Value
CEA-2031 Compliant
Size 12"
Impedance 2-Ohm x 2
Power Handling 400 Watts RMS
800 Watts PEAK
Sensitivity 86 dB
Motor Size 52 oz.
Voice Coil Diameter 2.5" 4-Layer
(6.35 cm)
Speaker Connector Dual 10 AWG compression
Mounting Depth 3.625"
(9.21 cm)
Rec. Sealed Enclosure 1.00 cu. ft. (28.88 liters)
Range: 0.60 cu. ft. - 1.20 cu. ft.
Range: (16.99 liters - 33.98 liters)
Rec. Vented Enclosure 1.25 cu. ft. (33.98 liters)
Tuning Frequency (vented) 45 Hz
Port: (1) 4" diam. x 12" long
Port: (1) 10.16 cm x 30.48 cm
Shipping Weight 16.30 Lbs.
(7.39 Kg.)
http://www.rockfordfosgate.com/produ...n_US&p_status=
Old Apr 6, 2007 | 06:34 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
image dynamics IDQ i second
the ID you can also do if you just remove the plastic magnet cover
elemental designs kv series you should be able to fit
as well as the 3" deep sq10
i have a good few installs as you described on my site, you can feel free to reference it
Old Apr 6, 2007 | 07:53 AM
Gilley's Avatar
Gilley
Bing, a couple of your stealth installs gave me this idea.
I still need the trunk to be functional, but I want to have more pizazz than my current 4080 box and hidden components.
Old Apr 6, 2007 | 08:05 AM
MR_X's Avatar
MR_X
Originally Posted by doug
+2
350z82
Oct 1, 2015 06:25 PM
