Can someone point me out to what a good amp kit and wires I need?
Old Apr 14, 2007 | 01:48 PM
TheGest's Avatar
TheGest
Default Can someone point me out to what a good amp kit and wires I need?
I have a Zapco 360 Amp.
2 Focal Speakers, no tweeters FAK2 Polykevlar
Ill be ordering a Double Din 5510BT Eclipse, plus 350z double din metra kit.
So I need tweeters,
metra kit
what wires should i get?
wrong forum, move this to audio please
Old Apr 14, 2007 | 02:01 PM
KManZ's Avatar
KManZ
For my 4 channel amp, I used a kit by Scoshe, which I got at Walmart. It comes with a power wire, ground wire, remote turn on, and a set of RCA's. Alls you need then is speaker wire.
Before you dog the Scoshe kit, check this out: from what I have read, the make/ quality of the RCA's in a wiring kit really make no difference... its more important that you wire your car correctly. Don't run your RCA's next to your power line, and you will not get any interference or alternator wine.
Because I was using a 4 channel amp and the kit only came with 1 set of RCA's, I had to buy another set. This was before I had researched, so I went to Circuit City and bought a $90 silver lined, super insulated Tsunami RCA cable. I wired it up to my front components, and it sounded good, and then I wired the Scoshe kit RCA's to see if there was any difference in quality: there was NONE. They sounded exactly the same.
So save yourself some money and check out the kit by Scoshe
Old Apr 14, 2007 | 02:02 PM
Mike Wazowski's Avatar
Mike Wazowski
Tsunami amp wiring kit
Old Apr 14, 2007 | 04:00 PM
TheGest's Avatar
TheGest
http://www.circuitcity.com/rpsm/oid/...oductDetail.do
this one?
Old Apr 14, 2007 | 04:57 PM
Mike Wazowski
I would get the 850 watt kit.
http://www.circuitcity.com/ssm/Tsuna...oductDetail.do
Old Apr 14, 2007 | 06:44 PM
doug's Avatar
doug
i went to my local audio store and bought everything seperate
Old Apr 14, 2007 | 09:32 PM
TheGest's Avatar
TheGest
Cool thnx man, So I got the amp kit, double din dash kit, gona order 5510bt trying to see if costco will get it soon,
also what wires do I need to hook up the crossover box to the speakers?
Old Apr 14, 2007 | 10:33 PM
Mike Wazowski
just some good 12 gauge wire would be fine.
Old Apr 14, 2007 | 11:32 PM
ZSpectrum's Avatar
ZSpectrum
I have knukonceptz wiring and its awesome
Old Apr 15, 2007 | 09:02 AM
Sup3rduperZ's Avatar
Sup3rduperZ
m_0g
Jun 3, 2021 10:05 AM
bcoffee20
Nov 19, 2015 06:39 PM
cashmoney03
Sep 27, 2015 05:24 PM
Beater350z
Sep 9, 2015 03:36 PM
