New Speaker For OEM Navi???????
Old Apr 21, 2003 | 09:11 PM
SmokinZ's Avatar
SmokinZ
Question New Speaker For OEM Navi???????
What kind of speaker do you get for your Nissan Nav voice to output to??? (After you have installed new HU and Speakers).
I have to be able to hear Navi voice or that is $2k down the drain.....
Old Apr 22, 2003 | 03:15 AM
tonkadog's Avatar
tonkadog
I'd like to know this as well. Also, did you have to amplify the signal before running it to the speaker? And, one last thing, which wires did you use to hook up the speaker? I have looked at Onecoolee's instructions, but his color codes don't match what I am seeing - not sure if it is just me or what?
Old Apr 22, 2003 | 04:50 AM
jhagan's Avatar
jhagan
I just had a new HU put in.. I'll ask the installer, when I get a chance to shoot by there and post here in a few days.. He used a basic NAV speaker that comes with one of these over the counter NAV kits.. an dplaced it on the right side in the passengers foot well facing me..
I'm sure it didnt cost much since he didnt charge me.. ANd I'm almost certain that he didnt modify the voltage output.. but I'll ask...
Old Apr 22, 2003 | 07:19 AM
SKiDaZZLe's Avatar
SKiDaZZLe
Charter Member #34
do a search on posts of audio by me.. i ended up using a kenwood amplified center channel.
Old Apr 22, 2003 | 08:32 PM
SmokinZ's Avatar
SmokinZ
yeah, i thought about using a center channel speaker , but damn, $150 (or more)??? jesus, you gotta be able to use a cheap speaker!!!???
also... i am having a hard time understanding which wires to use as well (per onecoolee's instruction)
what about like some type of intercom speaker or something???
Old Apr 23, 2003 | 02:47 AM
tonkadog's Avatar
tonkadog
I was hoping to use one of the stock clarion speakers from the rear, provided that the signal was amplified.
Anyone know if that is possible?
Old Apr 23, 2003 | 04:45 AM
Mikey Likes It's Avatar
Mikey Likes It
Charter Member #44
I used an Alpine SBS-0715. Ity comes with a 45W amp.
I mounted the speaker between the seats behind me. The amp is small enough to fit anywhere.
Mike
Old Apr 23, 2003 | 03:27 PM
SmokinZ's Avatar
SmokinZ
Again... $150 (or more) !!?!?!?!?!
I eyed the SBS-0715 and will probably end up biting the bullet and getting it, but my inquiry is CAN IT BE DONE WITHOUT SPENDING MORE MONEY AND RUNNING MORE AMPS!!!!
I also pondered using one of the door speakers (clarion) as the nav voice output... and am wondering the same question:
DOES IT HAVE TO BE AMPLIFIED?????
Old Apr 24, 2003 | 03:44 PM
customexotica1's Avatar
customexotica1
Default nav speaker
Any small speaker should work. The Nav system contains a small amp already and can power the speaker. I haven't torn into our Z yet so i can't verify the wire colors. If the speaker you choose does not have enough volume a 1-3 watt amp will help. You can find these in kit form from many electronic hobby kit suppliers, at a cost of about $8.
Old Apr 24, 2003 | 06:13 PM
SmokinZ's Avatar
SmokinZ
thank you very much.....
Old Apr 25, 2003 | 04:00 AM
tonkadog's Avatar
tonkadog
Default Re: nav speaker
good to know, thanks!
3vilbunny
Jul 18, 2017 05:10 PM
kyin
Oct 15, 2015 05:54 AM
