quick wiring question
Old May 9, 2007 | 03:46 PM
push's Avatar
push
Default quick wiring question
I have all the wires run to the nav and gps (kna-g510 and lz702w) but I need to know where I tap into the power. There are wires for parking brake (grounding that one), reverse (not using), accessory, battery, and ground (obvious). My question is where do I tap for the accessory and battery power. I'm guessing from the stock head unit I would tap, but I'm not sure which wires are what. For the monitor I think it was it said don't connect the battery to the battery, so does that mean the accessory and battery for the monitor are going to be tapped to the accessory of the factory head unit?
Old May 9, 2007 | 03:49 PM
push's Avatar
push
Are these the proper wire colors for the wiring harness for the factory radio?
Radio Constant 12V+ Wire: Yellow (battery wire from the head unit?)
Radio Switched 12V+ Wire: Light Green (I would tap the accessory wires here)
Radio Ground Wire: Chassis
Radio Illumination Wire: Red/Blue
Radio Dimmer Wire: n/a
Radio Antenna Trigger Wire: Green/Yellow
Left Front Speaker Wire (+): Blue/Red
Left Front Speaker Wire (-): Black/White
Right Front Speaker Wire (+): Yellow/Red
Right Front Speaker Wire (-): Red/White
Left Rear Speaker Wire (+): Light Green/Red
Left Rear Speaker Wire (-): Black/Yellow
Right Rear Speaker Wire (+): Blue/Orange
Right Rear Speaker Wire (-): Black/Pink
Old May 11, 2008 | 07:24 PM
Allano's Avatar
Allano
Anyone can help with this?
Old May 12, 2008 | 02:17 AM
StreetOC192's Avatar
StreetOC192
Assuming you are ADDING ON a nav in the cubby above the OEM radio. Then your question about constant and switched power sources was semi-answered already by push:
The switched +12v on your nav and screen should just be turn on signals and therefore draw very little so you could use the Light Green wire behind the OEM headunit. HOWEVER, I would be discouraged by the current draw of the nav and screen system you bought to just tap into the headunit's resources for constant +12v. You are better off running a FUSED constant +12v from the battery.
Old May 12, 2008 | 02:52 AM
Allano's Avatar
Allano
I really appreciated your reply on this topic. However, I am acutally looking for the solution as I posted in another thread and as follows:-
Hi, I am new here. I am planning to change the head unit to Pioner AVH-P6050DVD. Can anyone of you help me in wiring? I found out there are 3 sockets and as follows:-
6-Pin Socket
Grey
Black/Yellow
Purple/Red
Pink
Light Green
Blue
8-Pin Socket
Yellow/Red
Light Green/Red
Blue/Red
Grey/Red
Grey
Blue
Pink
Grey
9-Pin Socket
Orange
White
Red
Green
Green/White
Grey
Pink/Black
Red/Black
Blue/White (Big wire)
Which wire represents the speaker wire (LL, LR, RL, RR)? Do I have to use RCA to connect to the stock amp or directly connect the new head unit high output to the respective wire in the socket?
Thanks.
Old May 12, 2008 | 03:53 AM
StreetOC192
Allano, There is a sticky at the top of the Audio sub-forum that details what the wire colors are for. start there.
Old May 12, 2008 | 04:15 AM
Allano's Avatar
Allano
You mean this?
audio:
Radio 12v yellow + radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
all wiring guide courtesy of DEI[/QUOTE]
Only 3 wires matched with the wires I mentioned in the 3 sockets.
Old May 12, 2008 | 04:25 AM
StreetOC192
You mean this?
audio:
Only 3 wires matched with the wires I mentioned in the 3 sockets.[/QUOTE]
What year is your Z? Does it have the Clarion headunit or Bose headunit? Is it USDM or JDM? Did you not get harness adapters with your new headunit? Perhaps you could purchase harness adapters to make your install easier.
Sorry for going OT push!
Old May 12, 2008 | 05:33 AM
Allano's Avatar
Allano
Year is 2003 and equiped with Bose system. I can't get an adapter here because I am from Malaysia. Hopefully someone can help me out.
Old May 12, 2008 | 05:46 AM
StreetOC192
With the factory Bose system, you can't just 'swap out' the headunit without the proper adapters.
Old May 12, 2008 | 05:49 AM
Allano's Avatar
Allano
Yeah, I noticed that. But I must first find out the respecitve speaker wires and then try to modify the radio wire harness or use a hi-to-low for conversion of signal.
Old May 12, 2008 | 06:10 AM
StreetOC192
You can't just add LOC to the speaker outs and expect it to work. Bose has a proprietary topology interaction between the headunit and amp and speakers that work as a single system. Replacing one part disrupts the balance. There is a PAC adapter that you NEED to use. I did a search (very simple to do) and found this link for you:
http://www.sonicelectronix.com/item_...ROEM-NIS2.html
This PAC adapter removes your need to locate a wiring guide.
If you would like I can fly out to Malaysia to install the headunit too.......
Old May 12, 2008 | 06:16 AM
Allano's Avatar
Allano
Thx alot. I will try to order that PAC adapter. When installation done, I will try upload the pic here
By the way, the PAC is for 1995 - 2002 Nissan vehicles with Bose audio system , will it work?
Old May 12, 2008 | 06:24 AM
StreetOC192
It seems to have worked in this install:
https://my350z.com/forum/audio-video-and-electronics-diy/354914-install-guide-bose-kenwood-dnx7100-pac-roem-nis2-03-cubby-painted-cubby-monitor.html
Old May 15, 2008 | 10:51 PM
Allano's Avatar
Allano
https://my350z.com/forum/showthread.php?t=354914
Street, do you know any other sites which I can buy the ROEM-NIS2? I have ordered from sonicelectronix but still subject to international verification up-to-date. Zzzz....
350Z_Al
Oct 29, 2020 07:44 PM
Mattg350z
Oct 2, 2015 06:51 AM
nanotech
Oct 2, 2015 05:02 AM
