Look what UPS brought *part 2*
Old May 10, 2007 | 05:56 PM
push's Avatar
push
Default Look what UPS brought *part 2*
Got this in on Wednesday around 5-6ish:
The screen:
The GPS unit:
The installation, half way through running the wires:
Nav box placement, pardon the dust:
Old May 10, 2007 | 05:57 PM
push's Avatar
push
GPS Ant:
Installed:
Boot:
The nav working:
All in all it works great, syncs up really quick, calculates routes very quickly and has an amazing interface. I really liked how the install ended up, it looks like it came from the factory, which is what I was going for, and it's very easy to conceal.
Old May 10, 2007 | 05:58 PM
soleil's Avatar
soleil
NolaZcc
nice...i have the kenwood 7100 and i absolutly love it
Old May 10, 2007 | 06:34 PM
Spike100's Avatar
Spike100
Very nice install... clean and stealth.
Your screen shot shows a nice feature of the Kenwood KNA-G510 Navigation Box. Since the GPS "knows" where you are and the time of day in your position, it can automatically invert the display (day or night viewing). I love that feature. At night, the background goes to black so it isn't too bright, and automatically goes to a white background during daylight hours for viewing under bright ambient light.
--Spike
Old May 10, 2007 | 06:35 PM
r0mey's Avatar
r0mey
very nice
Old May 10, 2007 | 06:59 PM
push's Avatar
push
--Spike
Yeah I love that. Just hope none of my connections come loose haha. I sodered/electric taped them pretty well though, and the grounds are below a nice tight bolt, so I shouldn't have any problems... Knock on wood.
Old May 10, 2007 | 07:13 PM
Get_Zwole's Avatar
Get_Zwole
how much did that run you?? just curious looks awesome man
Old May 10, 2007 | 07:20 PM
Dio1988's Avatar
Dio1988
goood work.... looks good
Old May 11, 2007 | 04:23 AM
push's Avatar
push
Got the monitor and nav box for $750 shipped
Miscellaneous things with the install added a little more. Plastic weld - $3, lighted switch - $5, velcro for the lcd brain and nav unit - $5. If you don't have a soldering gun you may want to invest in one just to make sure your connections don't come loose, those are about $10-15 plus solder. Everything can easily be done for < $800. Plus if you don't have the 03 cubby you will want one, I think those are like $90ish.
Old May 11, 2007 | 05:43 AM
THE TECH's Avatar
THE TECH
Very nice!!! Makes me rethink my choice a bit on the 7100.
Old May 11, 2007 | 05:47 AM
behjjeh's Avatar
behjjeh
Vendor - Former Vendor
wow!! sweet! i wish 06 cubby is $90ish........
Old May 11, 2007 | 06:04 AM
tranceformer95's Avatar
tranceformer95
Very nice, looks clean.
Old May 11, 2007 | 06:40 AM
Kieran@DrivenDynamics's Avatar
Maybe you tried it but incase you didnt, you can actually mount the GPS antenna underneath the plastic you currently have it sitting on. Did it for both my XM and GPS ant's and they still work just fine.
Nice install!
Old May 11, 2007 | 06:42 AM
push's Avatar
push
Nice install!
Yeah, I'm going to do that today, at the time I just wanted to make sure everything synced up ok. Is there a write up somewhere on how to take apart the back brace so I can put it in there? I made it this far without breaking any plastic, hoping to make it the entire way haha.
Old May 11, 2007 | 06:47 AM
I can tell you for sure after lunch, but I'm pretty sure I just pulled that top panel of the brace off without removing anything else. If anything you may need to take the trim pieces off from the side/rear first.
Old May 11, 2007 | 10:22 AM
Voboy's Avatar
Voboy
wow neat, no aftermarket headunit needed! and not one of those small screen portables!
Old May 11, 2007 | 10:55 AM
Push - those panels pop right off just takes some force.
Old May 11, 2007 | 11:15 AM
push's Avatar
push
Alrighty, I'll give that a try when I get home, thanks!
Old May 11, 2007 | 12:27 PM
push's Avatar
push
Just moved it, looks much better and gets better reception since the antenna uses the brace to amplify it's reception.
Old May 11, 2007 | 03:32 PM
Spike100's Avatar
Spike100
push,
That is just a great install... with everything where they should be. You took advantage of the best positions the Z offers for installing all the components.
You are certainly on top of the "Hall of Fame" of Z installs.
--Spike
