Farenheit Remote
Old May 17, 2007 | 06:22 AM
dragone2717's Avatar
dragone2717
Default Farenheit Remote
I've been looking for a thread about the remote for the Farenheit 7000. Will it ork with the t-7001?
Old May 17, 2007 | 11:45 AM
dragone2717
Anyone????
Old May 17, 2007 | 02:58 PM
Spike100's Avatar
Spike100
No. The Farenheit T-7000MHR and the T-7001MHR use different remotes. I have both, and you need the specific remote to operate the LCD.
Just curious: Why do you ask?
--Spike
Old May 17, 2007 | 03:09 PM
dragone2717
--Spike
Thanx
Becuz I have a T-7000 and just bought a used T-7001 for cheap on Ebay. It didn't have a remote but I didn't really care cuz of the price I got it for.
And..... Someone stupid inside my head told me it should work.
Old May 17, 2007 | 03:32 PM
Spike100's Avatar
Spike100
Thanx
The controls on remote for the T-7001 are very different (and, IMO are very confusing) than the remote for the T-7000.
If you don't have the remote, possibly you have been unable to operate the T-7001... But, if you've been able to run the T-7001, I am curious about your opinions of the two LCD's Farenheit T-7001MHR vs. Farenheit T-7000MHR.
Operation? Picture (and color) quality?
--Spike
Old May 17, 2007 | 03:38 PM
dragone2717
--Spike
let put everything in. And i'll let you know...
Old May 17, 2007 | 04:05 PM
Spike100's Avatar
Spike100
It's a lot of work taking apart the center console in the Z. Before installing the 7001, you should bench-test your new (the Farenheit T-7001MHR) equipment. You can do this by connecting your new purchase (the T-7001) to a 12 volt converter. That way you can see if it works before doing all the work this installation requires. The first Farenheit I bought was defective, but I knew this before I installed it because I tested the LCD on the bench using a 12 volt converter. That saved a lot of unnecessay work and time.
Notice that the T-7001MHR has a cheap headrest shroud that does double-duty as the back of the unit. This requires cutting (removing) the edge of the cheap shroud to allow installation in the upper/forward cubby space.
_____________________________
EDIT: If you install the T-7001MHR, how can you run the LCD for an evaluation if you don't have its remote control
--Spike
EnjukuRacing
Drivetrain
Sep 14, 2015 11:15 AM
rouxeny
Audio Builds
63
Sep 27, 2009 01:56 PM
KJ-350
Mar 17, 2003 03:11 PM
abz123
Jan 24, 2003 06:11 AM
