Those With The Farenheit Screen!
Old Apr 26, 2003 | 02:15 PM
03_ppw350z's Avatar
03_ppw350z
Default Those With The Farenheit Screen!
when you have your screen on and turn your radio on pretty loud does the picture on the screen scramble slightly when the bass hits a little. im not talking about sub base but midbass from the door speakers. i donot have subs right now. the wires are taped into the wires from the stereo harness but i don think that had anything to do with it since i ran the power wire to the cig plug and it still did the same thing?
Old Apr 26, 2003 | 03:56 PM
rouxeny's Avatar
rouxeny
No, I have no such problems. I'm sure it has to do with your wiring.
Old Apr 26, 2003 | 11:19 PM
03_ppw350z's Avatar
03_ppw350z
where did you tap into the power and ground at?
Old Apr 27, 2003 | 09:05 PM
03_ppw350z's Avatar
03_ppw350z
nevermind i ran the groundwire strait to the frame and now it dont flicker at all thanks anyways!
Old Apr 28, 2003 | 07:37 AM
KJ-350's Avatar
KJ-350
quick question...did you make/run it into any type of "remote" turn on? or do you just use the remote control each time you want to turn it on/off?
Old Apr 28, 2003 | 09:42 AM
greenis300want350z's Avatar
greenis300want350z
in the menu you can set the screen to turn on everytime it gets power or you can set it to turn on only when you turn it on with remote. i have it set to turn on when the car turns on
Old Apr 28, 2003 | 09:52 AM
KJ-350's Avatar
KJ-350
no ****! which one do you have? I have the T-7001. Its most likely right in front of face and Im passing it by but I cant find that option? Which one(s) is it under if you dont mind?
Old Apr 28, 2003 | 10:01 AM
03_ppw350z's Avatar
03_ppw350z
i have the 7001 and in the menu it says somthing like direct power on or off
Old Apr 28, 2003 | 06:58 PM
rouxeny's Avatar
rouxeny
Yeah, there's a direct on option somewhere in the menu. The menu system is pretty darn confusing though, and the "manual" doesn't really help at all
Workshop12
Mar 23, 2020 01:45 PM
jlb
Oct 15, 2017 05:10 AM
Tochigi_236
Sep 27, 2015 03:40 PM
GixxerBB
Audio Builds
39
Dec 9, 2002 08:08 AM
Z33Fan
Oct 15, 2002 08:27 AM
