Removing foam blocks from hatch area
Old May 24, 2007 | 10:31 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Default Removing foam blocks from hatch area
Hi all,
I want to remove the foam blocks from the hatch area tonight so I figured I'd ask here how they come out to save me some possible frustration.
I know there is one large plastic screw on each side that is readily visible, but didn't notice any other mounting points during the quick look I took.
Thanks.
Old May 24, 2007 | 10:45 AM
Kwame's Avatar
Kwame
Looks like 1 screw based on the passenger's side picture:
http://www.courtesyparts.com/betasit...14_715_846_861
Old May 24, 2007 | 11:03 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Great link. Thanks, Kwame. You DO realize your install thread started me on this "upgrade".
Old May 24, 2007 | 11:20 AM
Kwame's Avatar
Kwame
I saw you mention that in my thread. Hey I'm happy to be of assistance in your build as well.
Old May 24, 2007 | 12:08 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Thanks. I may take you up on that. Here is very quick system diagram of my upgrade. The sub is the only ?? part right now. I have nowhere near the talent to do what your shop is doing. Bing or Dom could handle that end of it, I'm sure, so I can't wait to see how they finish your hatch off.
Attached Thumbnails Removing foam blocks from hatch area-system-diagram-small.jpg
Old May 24, 2007 | 12:22 PM
VO...'s Avatar
VO...
Administrator
I've removed mine a couple times when I was customizing my rear spare tire well box. You are correct on the plastic large headed screw that sits on the top. What you might have difficulty with is pulling the foam peices out though. They sit on top of a bolt that is mounted to the trunk floor. What happens, is when you go to remove them you have to lift the foam up high enough to clear the bolt so you can remove it. But, the problem is that you won't be able to lift it high enough because the side trunk panels prohibit this. The outer edge of the foam is actually wedged up under the side panels. I had to remove the panels to get the foam out. I'm sure you could just use brute force and pull the foam thingys out, that is of course if you don't care about damaging them.
Old May 24, 2007 | 12:25 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Great info.... So I take it if you remove the side panels, then you could remove the foam without much damage?
Old May 24, 2007 | 12:27 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Let's try this system diagram.
Attached Thumbnails Removing foam blocks from hatch area-system-diagram-test.jpg
Old May 24, 2007 | 12:43 PM
VO...'s Avatar
VO...
Administrator
That is correct...
Old May 24, 2007 | 12:57 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Great! Thanks Valentino.
Old May 24, 2007 | 01:00 PM
VO...'s Avatar
VO...
Administrator
NP.
Old May 24, 2007 | 07:18 PM
DIGItonium's Avatar
DIGItonium
How are you going to reinforce the chassis? Dynamat or sound deadening "paint"?
Old May 24, 2007 | 07:54 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Not sure yet.
Old May 25, 2007 | 10:09 AM
VO...'s Avatar
VO...
Administrator
I used spray in bedliner through out the trunk floor since there are so many little crevices and uneven spots.. I used Dynamat on the hatch itself.
Old May 25, 2007 | 12:30 PM
DIGItonium's Avatar
DIGItonium
Did you figure an alternate method of storing the jacks and tools such that it doesn't squeak or rattle as well?
I'm just wondering about some little weight savings while using sound dampening material for my next project. It'll still have the trunk mat for the OEM look, but with some stuff underneath removed.
It all goes down the drain once I drop in a 12" sub
Old May 25, 2007 | 12:34 PM
VO...'s Avatar
VO...
Administrator
Not really, I just wrapped the wheel locks and tow hook in a T-shirt then stuffed them down there somewhere. No spare tire, no need for a jack.
I dropped a 12 down there. It hits nasty hard! It's put two 10's to shame. Tr00f.
Old May 27, 2007 | 12:44 AM
Mr X's Avatar
Mr X
Mike, here's a photo walk through of how to get the trunk taken apart from Brandons car.
Time to gut the trunk
Take that **** off
Pop off foam
Then the wheel retainer
out
Out comes the wheel
Then you have to get this foam stuff off
Make sure to get the remains
Then to get the foam out, there are two plastic screws on the right
And one on the left
Then a bunch of these hooks
Thats what they look like out
I then proceeded to take out the weather striping
Looks like a snake
Its sharp without it
The pile of parts removed is starting to get big
Next we pop out the back piece
The next group of photos are my montage of taking the trunk apart
Doesn't the trunk look clean now?
Old May 28, 2007 | 07:25 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Great stuff... thanks Dom!
Old May 28, 2007 | 07:27 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Valentino,
Do you have links to pics posted here of your 12" install? I'm looking for ideas.
Old May 28, 2007 | 08:12 AM
HIGHTECHZ's Avatar
HIGHTECHZ
I got the foam pieces out without taking out all the trim pieces. Get all the tire related crap out of the way, loosen the panel on the far back (including the hooks for the net) and remove all the fasteners for the foam. Then just start wiggling the pieces out.
