3 problems with install
Old Jun 7, 2007 | 06:42 PM
twentyinrims's Avatar
twentyinrims
Originally Posted by Hoggy
Whats up,
I am just about to start a install and need to know how much space there is behind the factory Nav screen/cubby. Do you think I could place a double din head unit (Japanese style twice the normal size) in place of the factory screen?
Thanks
Nope, there is some room back there but not enough for a double din head unit. I put a 7" screen there (in an 06 Z) using an 03 cubby. There is some work you have to do to the cubby to get it to fit but it looks pretty good. Pics coming soon. Not totally done yet but I'll be posting prob by the end of the weekend.
Old Jun 7, 2007 | 06:44 PM
twentyinrims
Originally Posted by LeMans 05
Wow. I love pissing contests.
Every grounding point has a different resistance, although slight. Even true earth grounds. Any electrical equipment that is wired together needs to be at the same ground potential, otherwise you get the 'ground loop', which basically is a voltage potential between the different ground points. It may be a very small potential, but even a little bit is enough to cause big headaches when dealing with sensitive electronics.
Man, I kinda knew about grounds but didn't realize this stuff. No I know. Thanks for the info.
Old Jun 14, 2007 | 10:53 PM
Spike100's Avatar
Spike100
Originally Posted by twentyinrims
Look champ, I needed help and I do not recall you answering my questions, however to those that did I appreciate it. Funny how you are the only one that has been *****in$ bout nada. I've been checking your other post and now I understand why you keep crying. I do recall saying that I wasn't being nasty and check my threads fool, I by no means try to start this kind of stuff with anybody and I consider all people on the board my friend, however, I truly feel the need to voice my mind now because your fingers been typing a lil too much. I could give 2 $hits what you find offensive and 2 more $****s if your not my friend. My way of joking with the public by saying 65 lookers...was a joke, were you 1 of them? If you were why didn't you answer? If you were not, what's your beef? Just answer the question and move on. CHAMP, IF YOU ARE BORED, CHECK THE ANYTHING GOES POST AND MAKE BETTER USE OF YOUR FINGERS. With that Chump, I hope you understand now, I DON'T GIVE A $HIT WHAT YOU THINK.
ooh!... ouch!... eeh! ...yikes that burns!
Now, don't get all bent out of shape. Hadn't visited the thread for a while and wanted to give a little more feedback.
--Spike
Uriyo_
Sep 8, 2021 08:46 AM
