03 nav cubby in my 06!
Old Jun 7, 2007 | 11:54 AM
MarkM's Avatar
MarkM
Default 03 nav cubby in my 06!
........but what a b**** of a job! The 06 dash has actually changed quite a bit when you offer up older pieces it's pretty surprising just how much.
I wanted nav, chose the Kenwood LZ 702W touch screen and KNA G520 nav unit. I had to hack the cubby to pieces and piece it together to get the bits to mate with the 06 central piece of dash. The only mod I did to the original car piece was shorten the bottom 2 connecting pins where the screws go into. It's not perfect, and I can't close the door, the main focus was getting the sides to fit right.....but I'm happy anyway!
Attached Thumbnails 03 nav cubby in my 06!-img_0148.jpg   03 nav cubby in my 06!-img_0147.jpg   03 nav cubby in my 06!-img_0146.jpg
Old Jun 7, 2007 | 11:56 AM
MarkM's Avatar
MarkM
one more pic I couldn't post above for some reason!
Old Jun 7, 2007 | 02:48 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
Looks nice actually. Good job.
Did you take any pictures of the sides/back where you "hacked" away to get the parts to fit? You know your fellow '06/'07 owners are going to ask.
Old Jun 7, 2007 | 02:52 PM
push's Avatar
push
Looks good, I am running the same setup (g510 instead of 20). How did you get the sides lined up? Just curious I used pieces of the plastic from the backing plate that came with the monitor.
Old Jun 7, 2007 | 02:55 PM
Voboy's Avatar
Voboy
Not bad at all! Where did you get the cubby from and can you get a cloes up of the skins? They look like they match well but I thought they were different?
Old Jun 8, 2007 | 09:37 AM
MarkM's Avatar
MarkM
The sides lined up because I cut away the bottom portion of the cubby, then reduced the height of the bottom 2 screw holes, the radius of the cubby sides match perfectly, just need all the other bits out of the way!
Sorry, no step by step pics, I wasn't sure it was even going to work, I just hacked and stuck until the faces met
The faces are the same colour and texture, but the door is much smaller. I did look into swaping doors, but tbh, I just wanted nav, I don't mind the open door
Anyway, I fitted it today, here's finished pics
Old Jun 9, 2007 | 07:59 PM
Voboy's Avatar
Voboy
looks good to me, so you bought:
http://www.trademotion.com/partlocat...=5&catalogid=2
http://www.trademotion.com/partlocat...=4&catalogid=2
Old Jun 10, 2007 | 07:25 AM
MarkM's Avatar
MarkM
yes that looks like it! I bought mine used though, but it was the 03 car's nav cubby, and yes the little finisher is required for the front of the screen.
Mine is actually stuck on with velcro, so I can lift the finisher off if I need to get to the buttons, holds it very tight, in fact it was the velcro which came with the Kenwood nav unit. If you want some closer pics, just ask
Old Jun 10, 2007 | 05:25 PM
Voboy's Avatar
Voboy
! I was wondering how you got the finisher on there. lol. cool things look pretty good. I may need to try this later on when I upgrade my setup.
Old Jun 10, 2007 | 06:37 PM
Takhteh's Avatar
Takhteh
Difference between g-520 and g-510??
Is 520 European, whereas 510 is U.S.? Looks great, btw!
Old Jun 10, 2007 | 09:04 PM
nzpv03's Avatar
nzpv03
great job! very clean ...doesnt sound fun though lol
Old Jun 11, 2007 | 03:48 AM
push's Avatar
push
That's the only difference I saw when I went looking for info on the g520.
Old Jun 11, 2007 | 03:51 AM
Dio1988's Avatar
Dio1988
pretty nice!! good work
Old Jun 11, 2007 | 07:15 AM
Takhteh's Avatar
Takhteh
haha.. i was gonna say.. bc damn.. I just bought this thing like two weeks ago! ..and they already came out with a newer model! ..lol
Push, thanks again for your help man.. plan to post pics, but have since decided to upgrade a few other things now, too, so once done .. will def post a thread somewhere!
Old Jun 11, 2007 | 07:17 AM
Takhteh's Avatar
Takhteh
..and the only difference i noticed immediately is the g-520 is in blue and ours in green?
OR can we play with the colors?
Old Jun 11, 2007 | 07:20 AM
push's Avatar
push
I know you can play with the route colors, not sure about the title bar colors, but it may be possible. I'll have to check when I go home today, I know you can change a lot though.
Old Jun 11, 2007 | 07:23 AM
push's Avatar
push
Awesome, let me know when you do, I don't wanna miss it. I'm actually going to modify my install a little bit. I want to be able to use the monitors auto-dim feature, but with the finishing plate in place it is always dim. So I'm thinking of cutting out a little section where the sensor is so it can sense the light better and only dim when it goes into "sunset mode". I was going to look in the manual and see if it could dim the screen when the nav dimmed it based on time. It gets a little bright at night otherwise
Old Jul 28, 2007 | 09:54 AM
flozada's Avatar
flozada
Hi guys,
I found this 06-07 panel for NAV system in trademotion.com, does anyone had used or knows about using this part for a non-nav 06 350z???
http://www.trademotion.com/partlocat...06&catalogid=2
Vigman
Nov 17, 2015 04:34 AM
TrboMike
North East
Sep 28, 2015 06:36 PM
416blueZ
Sep 25, 2015 10:00 AM
Sailors350Z
Sep 25, 2015 08:21 AM
