did anyone try to install one of these reverse cameras?
Old Jul 19, 2007 | 07:13 PM
sifuK's Avatar
sifuK
Default did anyone try to install one of these reverse cameras?
http://cgi.ebay.com/Wide-Night-Visio...QQcmdZViewItem
i got mine, but just wondering if anyone installed it. and wondering how it is installed. mounting it inside behine the liscense plate
Old Jul 19, 2007 | 09:53 PM
Blacryan's Avatar
Blacryan
Tell me how it works out for you. I really was looking at buying this one, I wanted a small one. But I want to see what other people have experienced on there cams. I want a good, small one w/ good night viewing heh.
Old Nov 28, 2007 | 10:11 AM
Watkins's Avatar
Watkins
Older thread, but it is relevant since I bought the camera and installed it on my car. The monitor I am using is Farenheit T-7000MHR which is only a single input, but I am also using a Garmin GVN52 so I had to use a Farenheit AVIR3 input switcher to use all the sources into the single monitor.
I think I spent a total of $30 on the camera with shipping and I can't complain about the results, it actually works pretty well at night too. I was originally going to mount it in less conspicuous location than the tag, but where I live and knowing a bunch of Police/Sheriffs and asking them, it is walking a gray line of legality (it's like people who put stickers on the tags) but it isn't obscuring anything so I decided to go that route.
Old Nov 28, 2007 | 12:25 PM
aleicgrant's Avatar
aleicgrant
Did you install the camera yourself?
Old Nov 28, 2007 | 12:50 PM
StreetOC192's Avatar
StreetOC192
Can we get a pic of the screen at night?
Old Nov 28, 2007 | 12:59 PM
jgregory124's Avatar
jgregory124
not bad I think I will order one
Old Nov 28, 2007 | 01:31 PM
Watkins's Avatar
Watkins
Yes, later on.
Yes.
Old Nov 28, 2007 | 02:31 PM
Watkins's Avatar
Watkins
These pictures were just taken today (11/28/07) at 6:20 PM EST.
The first picture is taken from my garage looking out to my driveway so you can see how dark it is outside. I can't see anything.
This picture is immediately after the first picture; I placed one tripod based yellow halogen worklight 6' behind my car, and what you are seeing is that image.
In my opinion, its pretty significant what you can see with the camera as compared to nothing at all, and when I think about how cheap it was to buy, I don't see any real loss in the deal.
Old Nov 28, 2007 | 02:45 PM
dkmesa350z's Avatar
dkmesa350z
I just ordered one very similar to replace my current one. I plan on mounting it in the peach on my license plate to immulate rapper Young Jeezy I followed this write-up on install and it was easy as pie:
https://my350z.com/forum/audio-video-and-electronics-diy/273813-diy-rear-view-camera-install.html
Here's what I have now:
Attached Thumbnails did anyone try to install one of these reverse cameras?-mountainsrear.jpg
Old Nov 28, 2007 | 03:25 PM
StreetOC192
not bad at all. for as inexpensive as it is that's decent night vision quality.
Old Nov 29, 2007 | 03:47 AM
Doba's Avatar
Doba
thats actually not bad, and a clean install. but what ever happened to just turning your head and looking out the back window.
this is a product for women, not for a 350
Old Nov 29, 2007 | 03:57 AM
StreetOC192
Not necessarily, I think it has its place.
1 - The a$$ of the Z is large and there isn't much of a rear window to look through. Backing into a spot can be easier with a camera such as this. I know at work I back into a spot that has a concrete wall, this camera would allow me to better judge how close I am to that wall.
2 - If you are tinted, this camera would come in useful at night when backing out of a driveway or a spot.
3 - The camera may allow you to see things on the ground behind you that you couldn't see otherwise through the window.
4 - This camera may get you a better view of the hot blonde in the white BMW 330i behind you at the traffic light
In no way should a back-up camera REPLACE the legally accepted format of turning around and looking out the rear windows before backing up your vehicle, but as illustrated above, a camera could prove to be a useful tool.
Old Nov 29, 2007 | 04:01 AM
Doba's Avatar
Doba
Cant argue with that !! does it zoom in and take snaps too :P
yes I can see how it can be useful in a car with poor rear window visibility.
Old Nov 29, 2007 | 07:33 AM
aleicgrant's Avatar
aleicgrant
I want it because with a roadster and top up the blind spots are crazy
Old Nov 29, 2007 | 07:34 AM
aleicgrant's Avatar
aleicgrant
Default install
Originally Posted by Watkins
Yes, later on.
Yes.
any chance you took pics of your install. How hard was it?
Old Nov 29, 2007 | 07:37 AM
aleicgrant's Avatar
aleicgrant
I wonder if they make an LED version
Old Nov 29, 2007 | 07:41 AM
aleicgrant's Avatar
aleicgrant
http://www.overstock.com/Electronics...cid=25608&fp=F
anyone thought about this unit?
Old Nov 29, 2007 | 10:25 AM
Watkins's Avatar
Watkins
Well, this is about the best I can do, it was very simple though.
This is the camera mounted into the tag. I used nothing more than a Dremel tool to make the cuts in the tag and in the car, and then I used a wire coat hanger to feed the camera wires through the grommet in the trunk.
To mount the camera I had to drill a hole in the tag, and behind the tag as well.
If you are looking at the rear of the car, and pull away the rubber trim molding, and the rear trunk panel piece. That gives you access to the rubber grommet which is where I ran the power and video wire through the car.
Now how you choose to hook up the rest of the connections is up to you. I am using a video input switch because I have multiple video connections going into one monitor so my setup at the connection is probably different than most, but that's the gist of the install, it's very simple though.
Old Nov 29, 2007 | 10:30 AM
Watkins's Avatar
Watkins
There's a bunch of threads detailing that type of install; I chose to go this route because it's dirt cheap and I didn't want to change my tag frame.
Old Nov 29, 2007 | 10:53 AM
aleicgrant's Avatar
aleicgrant
wow thats even better than I expected. Want to install mine for a fee
what type of head unit do you have.
