Need Help with new speakers!!!!!
Old Aug 11, 2007 | 07:09 PM
ill350's Avatar
ill350
Default Need Help with new speakers!!!!!
Question for all you stereo knowledgable Z owners out there. I just bought (brand new) a set of Infinity Perfect components for my Z. Replaced the front speakers, cause they SUCK, and I thought they were blown. The drivers side sounded very staticy and did not emit much sound, thus I assumed they were blown. 3 days ago (after I ordered my Infinities) I turned the car over and the stock speakers sounded fine. Anyway, I just got and installed the Infinity speakers today. However, the driver's side (same as the stockers) sounds staticy and virtually no sound is coming out of them. Although they could be blown, I thought it was odd that this is the same issue I had with the stock speakers, and BOTH the new Infinity woofer and new Infinity tweeter sounds the same. That would mean that they would both be blown......right? Is it possible the POS stock head unit is sending a bad or disconnected signal to the driver's side? If the speakers are not blown should I avoid using them until I get it fixed as the distortion may damage them? Please help!!!!!
Old Aug 11, 2007 | 07:21 PM
seekndestroy19's Avatar
seekndestroy19
could be the radio but i highly doubt it. check the wiring and make sure the speakers aren't grounding out or touching metal
Old Aug 11, 2007 | 07:30 PM
ill350's Avatar
ill350
IF the drivers side is not already damaged, will I screw it up by just changing the balance through the HU away from the drivers side for a week or so till I get around to taking it to a professional?
Old Aug 11, 2007 | 07:40 PM
seekndestroy19
yea. you should be fine with that. just make sure you dont hear any clicking or sound coming out of the speaker. also do you have the bose system in your car?
Old Aug 12, 2007 | 04:52 AM
ill350's Avatar
ill350
Yes, it is a Bose system
Old Aug 12, 2007 | 06:29 AM
seekndestroy19
aight it could be your blows system also lol. to fix it you might have to bypass it
Old Aug 12, 2007 | 09:37 AM
ill350's Avatar
ill350
-how do I "bypass it"?
Old Aug 12, 2007 | 09:57 AM
seekndestroy19
you need the jump the wires at the amp. if you search it you should be able to find a DIY
Old Aug 13, 2007 | 05:15 AM
ill350's Avatar
ill350
Anyone else have any sugguestions about this issue. I just bought these speakers and it soulds terrible!!!! Just want to fix it. Thanks
Old Aug 13, 2007 | 06:20 AM
Yokohamaz's Avatar
Yokohamaz
Dude it could be something as simple as a grounded speaker wire. Trace the wires. Its all in the wires dude. Hey look.... a kitty.....
Yz
Old Aug 13, 2007 | 08:54 AM
james840a's Avatar
james840a
Need more Info, Do you have a Stock Head unit with out Bose system or with the Bose system?
Haha never mind just read more.
Now you have to realize that the Bose system has a different Ohms then the aftermarket speakers and that maybe part of the problem with your new speakers. Or it could be in the amp of the 4ch speaker witch is located in the trunk area on the left side under the black foam block next to the spare tire.
Old Aug 13, 2007 | 11:01 AM
dj addicted's Avatar
dj addicted
I know I have a low post count, but I've worked in car audio before. If you do have the bose system, usually the speakers are 2ohm coming off the crappy amp they use. The speakers you put in are 4ohm. This can cause a lot of problems. Usually when it comes to replacing car audio parts, most people just yank everything out and start from scratch. There are ways around the amp, but that definitely does not sound like thats what you did. I would put your stock speakers back in and troubleshoot from there why they sound bad. If the car is still under warranty, drop it back off at a nissan dealership.
Old Aug 13, 2007 | 12:03 PM
james840a's Avatar
james840a
True, but i think the bose amps were an odd ohms, like 1.3 or something, somewere between 1 and 2ohms. Heres a link with some info https://my350z.com/forum/showthread....&highlight=ohm
This is the trouble about adding aftermarket to a bose system. Boses system is an Odd ohm rating, like a home system and just F's things up. Like you said most people just dumb the bose system all to gether and replace it with complete aftermarket stuff.
Old Aug 13, 2007 | 12:17 PM
dj addicted
very good link, and if that is the case, I would just replace everything. You'd be surprised on the difference with a good headunit and decent door speakers. Down the road a 4channel amp will make your Z sound like a concert hall compaired to the bose system.
Personally unless you are buying high end bose for your house... its all junk and completely worthless.
Old Aug 13, 2007 | 12:41 PM
james840a's Avatar
james840a
^+1
Old Aug 14, 2007 | 08:52 AM
Tackett's Avatar
Tackett
it sounds to me like you are still running out of the crappy bose amplifier. Just direct wire them from the headunit. Cut off the amplifier-side of the wiring harness (make sure you cut the right wire), route your new speaker wire from the door to the harness and solder them together. Problem solved, no more amplifier. The speakers should still work...albeit low volume. Now, the wires that you clipped off...solder them onto the new connection that you just made. Should work now if there is no wires grounded from the amplifier.
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
cashmoney03
Sep 27, 2015 05:24 PM
