Yellow Or Redtop
Old Aug 17, 2007 | 07:02 AM
dunpealhunter's Avatar
dunpealhunter
Default Yellow Or Redtop
Which battery is a better performer? which one can keep up with the demand of the amps better?
I have about 1400 watt stereo that I mostly play while the car is running. which is the best choice? or are they pretty close to one another?
Old Aug 19, 2007 | 10:07 AM
StreetOC192's Avatar
StreetOC192
If you always run the car while enjoying your stereo, then get the red top. The yellow tops are deep cycle batteries.
Old Aug 19, 2007 | 10:13 AM
Larold's Avatar
Larold
Actually, if you read the manual for the Red Top Optima's, you'll see that having a large audio system in your vehicle actually voids the warranty. The Red Top Batteries are not designed for large constant loads. Stick with the Yellow Top.
Old Aug 19, 2007 | 11:59 AM
StreetOC192
That's interesting about the red top warranty - thanks for the heads-up....I've never owned either of these Optima batteries, but am familiar with their technologies. I recommend (and use) Exide Orbital batteries.
Old Aug 19, 2007 | 12:15 PM
Mike Wazowski's Avatar
Mike Wazowski
I have been using the Optima Yellow Top for 3 years in my Z with a stereo system between 800 watts (current set up) and 1300 watts (former system). It has worked flawlessly. No cap installed either (a cap is nothing more than a band aid for a weak charging system)
Old Aug 20, 2007 | 12:56 PM
KPierson's Avatar
KPierson
I, too, would recomend a yellow top for audio installations.
Old Nov 15, 2007 | 08:22 PM
jamaicanj's Avatar
jamaicanj
Thanks for the info...I am considering this exact question...yellowtop or redtop
Old Nov 15, 2007 | 08:27 PM
VenomZ's Avatar
VenomZ
have been using yellowtop for years
Old Nov 15, 2007 | 08:55 PM
SuperBlack350z's Avatar
SuperBlack350z
yellow top because of it being a deep cycle.
Old Nov 16, 2007 | 05:34 AM
350zspl's Avatar
350zspl
i would use a kinetic 1400 or stinger 1000
money better spent
optimas are at least $ 150 -$ 200
might as well spend a couple bucks more and get kinetic or stinger
kyin
Oct 15, 2015 05:54 AM
Kilroy.Bukowski
Sep 26, 2015 11:24 AM
krazik
Jan 11, 2003 12:59 AM
knihc2008
Jan 8, 2003 01:06 AM
z461
Cleaning & Detailing
Dec 19, 2002 06:42 PM
