Can I add an amp/sub to the stock non-bose radio.
Old May 14, 2003 | 07:12 PM
Anthony Mantovani's Avatar
Anthony Mantovani
Default Can I add an amp/sub to the stock non-bose radio.
I have the 160 watt stock radio in my enthusiast Z. I have two 10" MTX subs with an amp laying around my house. Does anybody know if the stock head unit has rca jacks so I can hook it up. I didn't want to change the head unit, because I leased the car. Thanks for the help.
Old May 14, 2003 | 07:48 PM
2003z's Avatar
2003z
no rca jacks, but you can get a line level converter. I have a 4x75 amp, 2 channels feeding the front spkrs, and the other 2 bridged to 150w to a rear sub. rear speakers fed off the stock headunit without amp, and still need to set the fader to front, because the stock rear speakers are 32ohms/
Old May 14, 2003 | 08:13 PM
Anthony Mantovani
2003z, thanks for the info, I have a 250watt 2 channel amp, I would power the fronts and rears with the head unit, and use the amp to power the subs. Can I do that? I'm not familar with a line level converter, could you explain it a little more, I appreciate it. thanks
Old May 15, 2003 | 07:03 AM
nmilsaps's Avatar
nmilsaps
I added a sub and amp last weekend... I used a rca converter to tie into the the rear speaker line, and just used my amp to push the sub. I also ran the remote to the cig. lighter, instead of the radio.
Old May 15, 2003 | 07:52 AM
2003z's Avatar
2003z
That will work. Like nmilsap said, with a line lever, or RCA converter as its also called, you splice off the speaker lines, the high level signal goes in, and it converts it to a low level rca signal for the amp input.
Old May 15, 2003 | 08:15 AM
derekjsmith's Avatar
derekjsmith
You may also want to install base blockers on the stock speakers if you are installing an aftermarket sub and amp. It will help with the destortion.
sales@czp
Sep 23, 2019 03:30 PM
