bazooka sub replacement question
Old Aug 20, 2007 | 06:20 AM
jkim1978's Avatar
jkim1978
Default bazooka sub replacement question
i have a 10" bazooka tube and i need to replace the subwoofer that it came with..... can i replace the sub with any other sub? or does only specific sub fit on the tube???? cause i tried to replace the sub with a fosgate and the installer said that it does not fit.... any help will be appreciated.. thanks.
Old Aug 20, 2007 | 06:23 AM
350zspl's Avatar
350zspl
i am pretty sure most subs of the same size will work
Old Aug 20, 2007 | 06:45 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
The problem with the Bazooka tube is that it's a tube and has a pretty tight mounting. The frame of any other sub-woofer isn't going to have the room to mount inside the tight confines. The other issue which is likely less important is that Bazooka likely has an audio engineer on their staff (ya' think?) that possibly matched the length of the tube to match their selected driver - changing this designed sound is going to greatly effect the Qtc of the subwoofer vastly changing the sound.
If you like the sound of the sub-woofer you're going to have to match the Thiele-Small parameters of the stock driver, and the mounting ... good luck. I would just contact Bazooka for a replacement driver. Here's a source with four hundred Thiele-Small parameters for you to search: http://www.thielesmall.com/
Workshop12
Mar 23, 2020 01:45 PM
bcoffee20
Nov 19, 2015 06:39 PM
Vigman
Nov 17, 2015 04:34 AM
Suffolk350z
Sep 13, 2015 02:43 PM
torchkc
Sep 11, 2015 08:26 PM
