MTX 7402 Amp: Which subs?
What are some good subwoofers to match with this amplifier? I have a Zenclosures sealed box for two 10's. Anyone have any recommendations? I am open to all suggestions!
Here are the amp specs: (http://www.crutchfield.com/S-WkI1Ato...02&i=236TA7402)
» 2-channel car amplifier
» 100 watts RMS x 2 at 4 ohms (200 watts RMS x 2 at 2 ohms)
» 400 watts RMS x 1 bridged output at 4 ohms (600 watts RMS x 1 at 2 ohms)
» CEA-2006 compliant
» MTX Prizm EFX selectable color display
» variable high- and low-pass filters (40-350 Hz)
» quasi-parametric EQ (cut/boost 0-12 dB at 30-80 Hz)
» Active Resonance Control (cut 0-15 dB at 200 Hz)
» speaker-level inputs with Smart Engage
» Xtant Technologies Cooling internal thermal management
» full-range Class-AB amplifier design
» MOSFET power supply
» fuse rating: 35A x 3
» 4-gauge power and ground leads recommended — wiring and hardware not included with amplifier
» 20-11/16"W x 2-1/2"H x 9-5/8"D
That is a great reco Ichigo, thank you. I am going with one of these, would you folks help me choose? I prefer quality over loudness. I will purchase two of whichever subwoofer I choose to go into a sealed Zenclosures box.
1. Alpine SWE-1042
» 10" 4-ohm subwoofer
» Kevlar®-treated pulp woofer cone
» high-excursion Santoprene rubber surround
» dual oversized Nomex® spiders
» frequency response: 32-1,000 Hz
» power range: 50-250 watts RMS
» peak power: 750 watts
» sensitivity: 87 dB
» top-mount depth: 5-3/4"
» sealed box volume: 0.6-1.25 cu. ft.
» Recommended Q-Logic Box Type: 1, 2, 3
» warranty: 1 year
2. MTX Thunder T5510-04
* 10" 4-ohm subwoofer
* mica-filled polypropylene cone with rubber surround
* expanded poly cone dustcap
* stamped steel basket
* chrome terminals accept up to 8-gauge speaker wire
* frequency response: 35-150 Hz
* power range: 150-300 watts RMS
* sensitivity: 88.25 dB
* top-mount depth: 6-1/8"
* sealed box volume: 0.75 cubic feet
* ported box volume: 1.25 cubic feet
* Recommended Q-Logic Box Type: 1, 2, 3
* warranty: 1 year
3. Infinity Reference 1050w
» polypropylene woofer cone with large-roll rubber surround
» innovative basket design minimizes depth
» progressive spider design for excellent cone control
» frequency response: 25-400 Hz
» power range: 60-250 watts RMS (1,000 watts peak power)
» sensitivity: 91 dB
» top-mount depth: 4-9/16"
» sealed box volume: .75 cu. ft.
» ported box volume: 1.75 cu. ft.
» warranty: 1 year
1. Alpine SWE-1042
» warranty: 1 year
* warranty: 1 year
» warranty: 1 year
I have that exact amp in my car. I am running a 12" kicker L7 off of it and it hits really hard. Amp is really nice to, my old kenwood amps would shut off sometimes with the stupid Las Vegas heat
And to answer out of those. Do not get the Type-E line from alpine, just not the greatest stuff. I would stick to the MTX, as I have also never been a fan of Infinity's products. You may want to check into some Kicker CompVR's, JL Audio W3's, or maybe a sub from Alpine's Type-S Line
Thanks for the heads up. I do not know my way around when it comes to appraising the quality of all these subwoofers out today.
If anyone can recommend two great subs that will work WELL with the amp I'd love it.
T7510-04, Alpine Type S, Elemental Designs, Image Dynamics...too many choices.
bcoffee20
Nov 19, 2015 06:39 PM
Tochigi_236
Sep 27, 2015 03:40 PM
