Just Speakers with Bose??
Old May 20, 2003 | 10:22 AM
alienx's Avatar
alienx
Default Just Speakers with Bose??
Sorry if this is painfully obvious to everyone else, but has anyone just replaced the speakers alone with the BOSE system???
I've read most every post in here but can't remember if this was actually possible with the funky Ohm ratings.
Thanks. Andy
Old May 20, 2003 | 11:22 AM
toykilla's Avatar
toykilla
i dont remember the ohm rating on the Z's Bose system. But here is your answer:
Aftermarket speakers will mostly likely be 4 ohms.
A. If the Bose are less than 4 (2 or even 1 ohm) the aftermarkets will not play as loud. (depends on sensitivity as well)
B. If the Bose are 4 - 6 ohms, then you should be fine.
C. If the Bose are >6 ohms, you might blow your amps by placing a 4 ohm speakere there. Draws more current = more heat)
Old May 20, 2003 | 11:23 AM
toykilla's Avatar
toykilla
On some bose systems in other cars, sometimes the 1-ohm setups would play so soft that you couldnt hear them with the car running.
Old May 20, 2003 | 01:16 PM
nlauri's Avatar
nlauri
Default Re: Just Speakers with Bose??
Thanks. Andy
I replaced speakers and amps. Makes a HUGE difference. The Bose amps are pitiful and you might not be happy with just replacing speakers. Good luck.
Old May 20, 2003 | 04:24 PM
dbpoet's Avatar
dbpoet
Talking
Last week I replaced just the door speakers with Polk EX3560 components I goy on ebay. They play just as loud as the Bose speakers but they sound much better. I can actually hear individual instruments which I couldn't with the Bose. Much more overall bass also, they don't sound tinney like the BoseWhat other posters have said about the front being the soundstage seems to be right. I doubt if I'll replace the rears, I just use them for a little bit of fill.
m_0g
Jun 3, 2021 10:05 AM
3vilbunny
Jul 18, 2017 05:10 PM
bcoffee20
Nov 19, 2015 06:39 PM
kyin
Oct 15, 2015 05:54 AM
