Bing or any electronic GURUs
I was planning on making some kicks for some 8s. The passenger side is perfect, with some big holes to vent outside. But unfortunately on teh drivers side those same holes hold two fuse boxes? has any one ever relocate those?? would anyone recommend doing it?
thank you
thank you
if you are good wiring wiring, and dont mind taking LOT of time and extending all the wring, you can certainly fit 8s in the kicks and get enough air space, wha ti suggest also is taking a plasma cutting and cut out the front part of the metal to get to the big cavity behind there
doable,yes, but qiute a bit time consuming
b
b
I honestly do not want to make door pods for my door, sooo hard to make look good due to the shape of the door... The kick panels seem like a perfect place due to so much space. The plan is to put JL 8ib4 in the kicks, scan speak 12m in the doors, and rainbow cal27 in the pillars.
i do have to agree that the midbass in doors is probably a better choise...for an 8"...
as for the 8ib4, thats a rather deep speaker, are you going to do AP venting as well?
here is the 8" pod i made once
https://my350z.com/forum/audio-builds/238788-my-my-what-big-door-pods-we-have.html
b
b
https://my350z.com/forum/showthread.php?t=238788
b
b
thank you
troy 9
i enjoy both
pods and kicks
nothiing like 4 midranges and 4 tweeters for your front stage
also i might install 2 more tweeters in my a pillars on each side for a total of
2 x 6.5 " in pods
2 x 5.25 " in kicks
2 x 1" in door panels
2 x 1" in kicks
4x 1" in a pillars
for a 12 speaker front stage
i enjoy both
pods and kicks
2 x 6.5 " in pods
2 x 5.25 " in kicks
2 x 1" in kicks
4x 1" in a pillars
Originally Posted by 350zspl
troy 9
i enjoy both
pods and kicks
2 x 6.5 " in pods
2 x 5.25 " in kicks
2 x 1" in kicks
4x 1" in a pillars
i enjoy both
pods and kicks
2 x 6.5 " in pods
2 x 5.25 " in kicks
2 x 1" in kicks
4x 1" in a pillars
pioneer avic d3
Stinger 1000 dry cell
Stinger 680 x 2 dry cell
wrangler 200 amp alt
Zed Duece 2 channel 400 x 2 @ 2 ohm
Rockford fosgate T40001bd
CDT Gold 6.5" & 1" # ES-062I ( EX-560I Transient Optimized” Elliptic 4th order 2 way crossovers) in pods
CDT Gold 5.25 " & 1" # ES -052I ( EX-560I Transient Optimized” Elliptic 4th order 2 way crossovers) in kicks
i use 1 of 3 enclosures
RE MT 12" in 3 net cu tuned to 45 hertz 2 x 4" aeroports
FI BTL 12" in 3 net cu tuned to 40 hertz slot port
RD Audio 15" Alpha V.2 in 3.25 net cu tuned to 30 hertz 2 x 4" aeroports
Stinger 0 awg
Rockford Fosgate Distribution Blocks and Terminals
no rear fill
Stinger interconnects
everything is installed
the only thing that is not in is my kicks which Bing should be shipping 2 nd day air to me tommorow
Stinger 0 awg
no rear fill
and the other thing is my 4 tweeters in my a pillars i am getting the 3/4" CDT # tw19 and they will be mounted 2 each on each a pillar reflecting off windsheild
they run off my existing cdt crossovers as image enhancement tweeters -3 db less than the main tweets which are DRT-26 cdt extended range modular silk
all my tweets are silk i hate metal tweeters
pioneer avic d3
Stinger 0 awg
no rear fill
Stinger 0 awg
no rear fill
he wont have it yet, cause i am in the middle of molding his kicks lol...
oh by the way, i got your PM, i will get it back to you by this weekend
b
b
its possible, like i said, but you need:
1. a lot of time and good wiring skills to extend and move aside all existing wiring
2. a plasma cutter to cut out the inner layer of metal
3. fiberglassing skills to create your cavity and kick panel
4. AP vent tuning skills to vent to the wheel well area
#3 and #4 im ok, but a lil too scared for #1 and #2. guess ill take it to a mechanic shop and see if they can move it for me.
thanks for the advices
b
b
if i can see by this Friday than your just too professional
best regards
