Hard wiring V1 (radar)?
Old Oct 6, 2007 | 04:57 PM
VIZAGE's Avatar
VIZAGE
Question Hard wiring V1 (radar)?
I'm wanting to finally hard wire my radar. I know somewhat when it comes to basic simple electronics, so far as 12v source and ground. I have everything needed for it came with the kit.
Question is will it be OK to splice the 12v wire into my existing gauge that I have in the gauge pod on the pillar? These gauges I have are Defi Bf series. There's only one wire there jumping from gauge to gauge, in which I assume is the 12v wire. Will have to put in a grounding screw to have it grounded to the frame (pillar). Would this be correct? AND IS IT ALRIGHT TO SPLICE THIS WIRE ON THE GAUGE ITSELF? It's just one of those clamp on clips (no cutting). Any help would be much appreciated.
Old Oct 6, 2007 | 05:14 PM
Beeker's Avatar
Beeker
As long as it is a switched 12v wire then you should be fine. If it is a constant 12v then your Valentine will stay on when the car is off. Since it is powering your gauges I have to assume it is switched.
Old Oct 6, 2007 | 05:42 PM
VIZAGE's Avatar
VIZAGE
That is correct. Thanks.
Old Oct 9, 2007 | 10:41 AM
tquill's Avatar
tquill
I don't know if you've already finished your hardwire but there is a much easier way IMO if you're still interested. Doesn't require any splicing whatsoever.
Old Oct 9, 2007 | 11:12 AM
NextLevel's Avatar
NextLevel
I am thinking about doing it, could you explain more?
I was thinking of connecting to the rearview mirror wires
Old Oct 9, 2007 | 11:19 AM
sibble's Avatar
sibble
https://my350z.com/forum/audio-and-video/276180-my-v1-radar-custom-install-95-complete.html
Old Oct 9, 2007 | 11:26 AM
OffsetZ33's Avatar
OffsetZ33
I used an Invisicord - simple as can be:
http://www.invisicord.com/order.html
Old Oct 9, 2007 | 12:31 PM
tquill's Avatar
tquill
I think that actually may work, but I don't have the homelink mirror so that wasn't an option for me... I've heard that's the easiest route to go though.
Anyway for those who don't have the homelink mirror:
Get the mini add-a-circuit from auto-zone or pep-boys.
The "add-a-circuit" works simply like this:
1. cutt off the female connector supplied with the add-a-aicuit and crimp in the blue part of the red wire on the wire you just cut from the add-a-circuit
2. Unplug the 10amp fuse from the radio terminal in your fuse box.
3. There are terminals for 2 fuses on the "add-a-circuit". Plug the 10amp fuse into the proper terminal on the add-a-circuit, and a *2amp*(aka accesory fuse) into the other--Don't worry, the directions with the add-a-circuit tell you which terminal gets the original 10amp, and which gets the 2amp fuse.
4. Obviously connect the male end of the hardwire kit into the (now modified, see step 1) add-a-cicuit.
5. Ground the ground wire on any bolt connected to the frame under the dash
6. Plug the add-a-cicuit into the terminal from which you pulled the 10 amp side mirror fuse, test your mirrors and RD, button the fuse box up, and go!
It's actually really easy. I just put the hardwire stuff under the steering wheel behind on top of the plastic (under the dash).
Old Jan 10, 2008 | 06:18 AM
AlwaysNBoost's Avatar
AlwaysNBoost
when u used the invisacord to the back of youre mirror doesnt it run constant power to the radar detector because mine does
Old Jan 10, 2008 | 09:42 AM
Hella's Avatar
Hella
mine goes on and off with the ignition. You might have tapped the wrong pin.
Old Jan 10, 2008 | 10:09 AM
AlwaysNBoost
possible i thought i was was supposed to tap into the one wire that has pink in it i could be wrong
Old Jan 10, 2008 | 06:57 PM
AlwaysNBoost
THANKS you were right-good looking out
Old Jan 25, 2008 | 09:17 PM
THE ROADSTER's Avatar
THE ROADSTER
what color do you tap ?
Old Feb 3, 2008 | 03:39 PM
rkdiddy's Avatar
rkdiddy
The instructions that came with my cord from Stealth Cords has the following:
04-06 350z - black w/ pink wire
07+ - brown wire
Also for those interested I did a little searching online and found a coupon code for stealthcords.com for 10% off: nissan350z
It worked for me!
Old Feb 4, 2008 | 01:16 PM
TeamSpeed's Avatar
TeamSpeed
07+ - brown wire
It worked for me!
Rick, the invisicord is less expensive and the Infiniti version was a collaboration between G35/350Z owners and myself. Why the smoke and mirrors for your website, just come out and ask folks for input?
Old Feb 4, 2008 | 02:03 PM
rkdiddy's Avatar
rkdiddy
Hugh?
Just trying to help out.
Cheers.
Old Feb 4, 2008 | 02:33 PM
TeamSpeed's Avatar
TeamSpeed
Hugh? No smoke and mirrors (no pun intended) here.
Just a happy customer trying to help a fellow member out.
Cheers.
That is your website, per the registrar info, so I guess I am a bit confused. I guess I can see this, kinda like the Hair Club for Men, you are the owner but a customer too.
Old Feb 4, 2008 | 02:54 PM
350z26's Avatar
350z26
super investigator here...
Old Feb 4, 2008 | 02:55 PM
rkdiddy's Avatar
rkdiddy
LOL - too funny.
Old Feb 4, 2008 | 03:24 PM
THE ROADSTER
I got invisicord and installed in less then 10 minutes yesterday. The Valantine mount from County Joy is awsome and easy to install also .
