Disarm factory alarm $$$$ reward $$$$
Old Oct 11, 2007 | 09:40 AM
chaakas's Avatar
chaakas
Smile Disarm factory alarm $$$$ reward $$$$
I need my factory alarm disarm…. Or uninstalled… its freaking driving me crazy… it goes of every morning between 9-9:30 am. Please help…..
Old Oct 11, 2007 | 09:50 AM
marques1's Avatar
marques1
i have never even heard my alarm go off one time before im not even sure if it works or not lol.
Old Oct 11, 2007 | 09:53 AM
chaakas's Avatar
chaakas
my alarm is crazy...
Old Oct 11, 2007 | 09:56 AM
SuperBlack350z's Avatar
SuperBlack350z
i believe the stock horns have wire hanesses, unplug the harness. Correct me if i'm wrong. my old car was like that.
Old Oct 11, 2007 | 10:02 AM
06blueZ's Avatar
06blueZ
This may be related to a bad door or trunk switch...
Old Oct 11, 2007 | 10:40 AM
DVFlyer's Avatar
DVFlyer
Speed of White
I've never heard mine either.
Old Oct 11, 2007 | 12:27 PM
chaakas's Avatar
chaakas
Thanks… I’ll try it tonight….
How can I check for this?
350z roadster…. just in case
Old Oct 11, 2007 | 02:53 PM
DavesZ#3's Avatar
DavesZ#3
It's not an alarm clock so it's not going to just "go off" at the same time daily. Something must be happening to set it off. Go sit outside by your car tomorrow morning during that time period and see what happens.
Un-plugging the horn is not the recommended fix, what happens when you're driving and need it?
Old Oct 12, 2007 | 07:35 AM
chaakas's Avatar
chaakas
I have being right next to my car and the alarm just goes off. The doors are close, the trunk is shut, and there’s nobody near the car. It just goes off!! its driving me crazy!!!
Does anybody know how to disarm the alarm?? Help…. If someone does help me I will reward this person….. $$$$$$$$
Old Oct 12, 2007 | 08:08 AM
scrillator's Avatar
scrillator
My guess is that your keyfob is malfuctioning. Take it apart, clean the contacts for the buttons, put it back together. Perhaps change the battery in it.
Just a guess.
Old Oct 12, 2007 | 08:58 AM
chaakas's Avatar
chaakas
Just a guess.
keyfob??? do you mean the alarm remote??
Old Oct 12, 2007 | 09:30 AM
scrillator's Avatar
scrillator
Yes. Your keyless entry remote.
Old Oct 12, 2007 | 09:32 AM
chaakas's Avatar
chaakas
Thanks, i'll try it
Old Oct 12, 2007 | 09:50 AM
DavesZ#3's Avatar
DavesZ#3
It could be the keyfob, but if that was the case, wouldn't it be going off anytime he's near the car, not just every morning between 9am and 9:30?
Old Oct 12, 2007 | 09:58 AM
noir06's Avatar
noir06
You don't lean against your bathroom sink or other counter with your keys in your pocket between 9:00 and 9:30 every day do you?
Old Oct 12, 2007 | 11:34 AM
chaakas's Avatar
chaakas
no... i think im out of range. i also leave my keys on my desk
Old Oct 12, 2007 | 12:17 PM
H.H.Holmes's Avatar
H.H.Holmes
Sorry it's me, I keep pressing your alarm button between 9:00-9:30am...just to freak you out. I will stop now.
Old Oct 12, 2007 | 01:39 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
don't stop, just do it at 3am while he's asleep
Old Oct 12, 2007 | 01:52 PM
Sean's Avatar
Sean
eliminate outside sourses as the root of the issue by taking a drive sat morning about 20 miles away, stop for food, wait to see if it goes off.
disconnect the battery for a few seconds, than reconnect. That should reset any possible clock timer that may be in the car. See if it changes the time that it goes off.
Old Oct 12, 2007 | 06:50 PM
XIceDragonX's Avatar
XIceDragonX
To test the trunk and door switches, you just have to use a circuit tester with the light in it, than hook the one end up to a ground, hit the other to one side of the switch and it should turn the light on, that's the positive, your lights might go on while you are testing it.... but than test the other side, that side should be negative when the door is shut... with the door open the circuit tester should light up no matter which side it is on... or something like that I am told.
