Bose problem. Not the common one though.
Old Oct 13, 2007 | 12:51 PM
Everybodywildou's Avatar
Everybodywildou
Default Bose problem. Not the common one though.
I've done some reading and I know people have problems with the sound cutting out on the left side w/ the bose system. The problem I'm having is that when I hit a bump my bass cuts out. Could it be a lose connection? Or is it a problem with the amp or headunit? Any input would be appreciated. Thanks.
Old Oct 13, 2007 | 06:44 PM
Everybodywildou
come on somebody give me some input. I hate posting in this subforum cause not enough people see it
Old Oct 14, 2007 | 08:39 AM
Paul350Z's Avatar
Paul350Z
Living in 350Z
THIS is the most common problem with the Bloze system (other than it sucks).
For the 5-10 people that have posted this complaint here I've recommended checking the connections behind the driver's seat and they've all gone away. Pull everything behind the doors out to pull the plastic down to the subwoofer and subwoofer amplifier and check those three connections.
Old Oct 14, 2007 | 09:57 AM
Everybodywildou
Hey paul thanks for the response. Is there a writeup on how to do it? I'm a little confused. The amp is in the trunk? Or is it behind the subwoofer?
Old Oct 19, 2007 | 02:59 PM
chortik2's Avatar
chortik2
i def have the same prob with the sub cutting out... it used to cut out once in a while and it would cut back on after i reach behind my seat and slam it a couple of times... buutttt.. it stopped pounding competely now... and its not loose connection cause i disconnected and reconnected it many times... and nothing...
soooo....
i decided to jus buy new subs (kicker cvx10) and i was wondering, other than wicked w.e... u call it... are there any other i could use to place the sub where the bose sub is?
and i dont wanna spend 300$ =/
thats why wicked is out...
Old Nov 23, 2007 | 11:43 AM
MECANICO's Avatar
MECANICO
Anyone have an update? Mine started to cut-off and would turn back on when I went over a bump as well. Now it completely stopped working. I'm in the process of taking it apart and checking it over for loose connections. Anyone find anything else besides a loose connection, bad amp..etc.?
Old Nov 24, 2007 | 08:36 AM
Everybodywildou
Its happening on your 07? Just take it back to the dealer. But if you find loose connections let me know! Check the amp for the sub behind the drivers seat.
liqalu04
Jan 2, 2022 12:58 PM
AbrasiveRaysive
Sep 20, 2021 02:29 PM
Uriyo_
Sep 8, 2021 08:46 AM
3vilbunny
Jul 18, 2017 05:10 PM
