My stock 6 CD changer just bit the dust now what??
Old Nov 5, 2007 | 05:35 PM
Jcolman's Avatar
Jcolman
Default My stock 6 CD changer just bit the dust now what??
I suppose it's time to upgrade. What are some fairly inexpensive but good options. I'm not a huge audio geek but I do like to listen to my CD's.
03' touring w/o nav if it matters any.
Old Nov 5, 2007 | 06:36 PM
Spike100's Avatar
Spike100
Your 2003 Touring model probably has the Bose “upgrade” CES. If that is the case, you definitely want to remain with that solution since CD changers use proprietary connections supporting their functions and features from the same manufacturer’s H/U. You do not want a “universal” CD changer since these usually require connecting to the antenna and deliver a lower quality sound via an FM modulator.
--Spike
Old Nov 5, 2007 | 06:37 PM
drivenCSZ's Avatar
drivenCSZ
i just saw a used OEM one on ebay for like 30 bucks.
or get an ipod...do they still make CD's?
Old Nov 5, 2007 | 06:46 PM
Spike100's Avatar
Spike100
^^ Good point. If your antiquated system is in failure, why not replace it with current technology. I cannot imagine any good reason to go backwards. CDs are pretty much a “dead-end.”
--Spike
Old Nov 5, 2007 | 10:58 PM
350ZTheStandard's Avatar
350ZTheStandard
Get a decent head unit with either a usb port or a aux in plug in and while you at it might as well replace the speakers and add a 10 sub in the box behind the drivers seat the way that Nissan did on the Bose system models. You can get the cover at your local Nissan stealership for about $10.00, and did I mention a amp get 2 of em, one for the front and 1 more for the sub in the back.
But then again your not really a huge audio geek. This will make the commute in your Z a pleasure, speed & music.
Old Nov 6, 2007 | 04:27 AM
Jcolman's Avatar
Jcolman
--Spike
Hmmm.....that's not a bad idea. I could also use a ipod on my motorcycle as well.
So can you guys point me to a decent replacement system for my car? Would the Pioneer AVIC-D3 be a good replacement? I saw this on another post and I like the idea of adding a nav system however the price is a bit steep.
Or would adding the USA Spec PA11-NIS be a better option?
I really don't mind keeping the current speakers and amp because like I said...I'm not that much an audiophile. Also, please excuse my ignorance but what is the "CES"? Some sort of connector??
Old Nov 6, 2007 | 03:09 PM
Spike100's Avatar
Spike100
^^ The answer depends upon your budget, what you want (navigation, better sound, etc.). If you are satisfied with the sound you have now, replacing just the H/U is an option. If your replacement H/U is not a Bose device (and I think your car has the Bose “upgrade), you probably need an adapter as well. You can find the part (Bose adapter) you need by doing a search on this sub-forum.
CES is an acronym for Car Entertainment System. The term includes all the audio/visual equipment in your car (H/U, LCD(s), amps, speakers, SubW(s), wiring, and add-ons such as a PlayStation).
--Spike
Old Nov 6, 2007 | 10:01 PM
350ZTheStandard
when you get the car stereo setup a smart idea would be a Microsoft Zune 30Gigs approx $240.00, bigger screen, you can bluetooth music to other Zunes, and best of all ot's not one of the "cutepods"
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
