tomtom one help
Old Nov 28, 2007 | 06:44 PM
typerilliard's Avatar
typerilliard
Default tomtom one help
hey i just got a tomom one but it doesnt fit in cuby...
is there any smaller suction cup mount for tomtom?
cuz i read some of u guys have tomtom one in cuby, but how?
Old Nov 29, 2007 | 10:33 AM
my05350z's Avatar
my05350z
good question, i am interested too. I have the same nav, been putting it on the windshield so far.
Old Nov 30, 2007 | 07:58 AM
BakaN20's Avatar
BakaN20
I'm not sure if this will work, but give it a try:
http://www.*********.com/zwiki/Garmi...350Z_cubbyhole
if it removes the main website, its at 350z tech with a dash in between.
Old Nov 30, 2007 | 06:48 PM
typerilliard
thanks but its for garmin not tomtom i guess
Old Nov 30, 2007 | 07:27 PM
Spike100's Avatar
Spike100
Your TomTom is small enough to easily fit inside the upper/forward cubby. Check the mount they call "ProClip." It's designed for shallow and versatile mounting. You may need to do some custom fabrication, but it will fit.
--Spike
Old Nov 30, 2007 | 08:22 PM
typerilliard
tomtom one fits inside but mount is the problem..
where can i find proclip?
Old Dec 1, 2007 | 01:45 PM
Spike100's Avatar
Spike100
^^ Here is the web page.
http://www.tomtom-proclip.com/?secti...p_leftorright=
It appears the mount is narrow enough to fit the cubby space. I think you will need to fabricate your own mounting plate. I wouldn't drill into the back of the cubby. It would be better to make your own plate and drill into that. Then attach it with double-sided tape. or any adhesive pad that releases when heated (hair dryer).
--Spike
Old Dec 1, 2007 | 06:28 PM
typerilliard
thanks for help but did u do this install?
looks like it wont fit, i sticks out too much..
actually i just bought garmin i3 suction cup mount, hope that fits tomtom..
Old Dec 1, 2007 | 07:22 PM
Spike100's Avatar
Spike100
^^ The mount I referenced protrudes < 1.5”. That fits with room to spare. Of course you need to do a minor custom fabrication job (making a base/plate that you screw the ProClip mount into). Your “custom fabricated” base/plate is then attached to the rear wall of the upper/forward cubby (using double-sided tape or any adhesive pad that will release when applying heat so that it is a reversible installation).
The Garmin mount you bought will work as well. You may need to do a little custom fabrication on this piece.
--Spike
Old Dec 2, 2007 | 03:02 PM
typerilliard
thanks alot spike, i m just waiting for garmin mount lets see whats up.
Old Mar 31, 2008 | 07:59 PM
surfcity40's Avatar
surfcity40
I just put in the TOMTOM One XL S text-to-speech in the cubby perfectly with the provided suction mount and mounting disc. It mounts sideways and aims the unit a bit to the driver. Perfect fit. Looks almost like it came with the car.
btw, the S has bluetooth to manage the phones
Old Apr 1, 2008 | 05:45 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Surf just out of pure curiosity--you have any pics of this mounted? id like to see what it looks like.
Old Apr 4, 2008 | 02:47 PM
surfcity40's Avatar
surfcity40
Here's one.
