Need help with wiring output converter
Old Dec 14, 2007 | 01:25 PM
n1sm0r's Avatar
n1sm0r
Default Need help with wiring output converter
Hey
I have a non-bose stereo, and I'm in the process of adding my amp and subwoofer. I want to keep the stock stereo just for simplicity sake, but I just need some tips on installing the line output converter so I can use a speaker signal to communicate with my amp.
What do you stereoguys recommend? I was hoping to get the signal from the rear speakers so I can put the output converter closer to my amp (less wiring, easier to hide wires etc). What wires should I splice into?
Just to clarify, this amp will only power my subwoofer, not the rear speakers, but I need to get my signal for my output converter from the rear speakers
Any ideas?
Input greatly appeciated
Old Dec 14, 2007 | 07:54 PM
w8lifter21's Avatar
w8lifter21
Easier to pull the radio and and grab them from back there, unless you're replacing the rear speakers. Yes your sub amp will only power the sub.
Old Dec 14, 2007 | 07:55 PM
w8lifter21's Avatar
w8lifter21
audio:
Radio 12v
yellow
radio harness
Radio Ground (chassis)
Radio Ignition lt. green + radio harness
Radio Illumination red/blue + radio harness
Factory Amp Turn-on green/yellow + radio harness
Power Antenna green/white + radio harness
LF Speaker +/- blue/red - black/white +,- radio harness
RF Speaker +/- yellow/red - red/white +,- radio harness
LR Speaker +/- lt. green/red - black/yellow +,- radio harness
RR Speaker +/- blue/orange - black/pink +,- radio harness
all wiring guide courtesy of DEI
Old Dec 14, 2007 | 10:39 PM
n1sm0r's Avatar
n1sm0r
thanks dude! appreciate it. I was advised to wire in my output converter in parallel rather than in series, so I'll just be slicing the wires at the speaker terminals.
m_0g
Jun 3, 2021 10:05 AM
350Z_Al
Oct 29, 2020 07:44 PM
sales@czp
Sep 23, 2019 03:30 PM
Fixxxercask
Interior
Oct 6, 2015 10:17 AM
nanotech
Oct 2, 2015 05:02 AM
