Can I replace the base headunit with the Bose?
Old Jun 8, 2003 | 06:37 PM
synth19's Avatar
synth19
Default Can I replace the base headunit with the Bose?
I want the car looking stock....and want a 6 CD in dash CD player. Is the Bose headunit the same as the Base headunit. (same size and fit?) Can I do this switch? Will it affect the Navigation system? Do I need to upgrade speakers and amps? thanks!
Old Jun 8, 2003 | 08:16 PM
westpak's Avatar
westpak
SFZCC
It fits physically and the pulgs for the wiring are the same size, but it just didn't work.
The sound was very low like it nneded amplification and scratchy. There are a couple of wires missing from the base harness to the bose, someone with some electronic expertise might get iot to work but not a straight replacement.
Old Jun 8, 2003 | 09:32 PM
jeffa's Avatar
jeffa
The Bose head unit does not have amplifiers in it. It is a line level differential output. You would need the Bose amp to make it work, along with the wire harness from the dash to the rear hatch area.
So, bottom line answer...the Bose head unit will NOT work in a non-Bose car.
Old Jun 9, 2003 | 09:04 AM
toykilla's Avatar
toykilla
i completely disagree.
i say it WILL work but you must use aftermarket amps to run the speakers.
then you get 6disc in dash changer and better sound(amps) win-win situation
Old Jun 9, 2003 | 10:28 AM
jeffa's Avatar
jeffa
He asked if it would directly work in a non-Bose car. Did not specify using aftermarket amps.
So, by using a differential converter made by PAC, Soundgate, or others, yes it will work in a non Bose car by ADDING aftermarket amps....
Old Jun 9, 2003 | 04:15 PM
toykilla's Avatar
toykilla
Default Re: Can I replace the base headunit with the Bose?
Originally posted by synth19
........ Do I need to upgrade speakers and amps? thanks!
i believe he did ask this question
Old Jun 9, 2003 | 07:42 PM
synth19's Avatar
synth19
Do you guys think this would be an expensive install/complicated? Would it be difficult for a shop to figure this out, or is this more common then I think.........with the navigation variable
Old Jun 11, 2003 | 07:33 AM
Ryde's Avatar
Ryde
I'll sell you my bose system...amp and all tho w/o the speakers If you want to try it
Old Jul 17, 2003 | 06:53 PM
synth19's Avatar
synth19
sorry to rehash this thread, but I'm still thinking of doing this. Will the Navigation function fine if I replace the basic headunit with the BOSE?
sales@czp
Sep 23, 2019 03:30 PM
dcains
Nov 11, 2015 11:36 PM
