Just a double check
Old Dec 25, 2007 | 07:14 PM
sirfatty's Avatar
sirfatty
Default Just a double check
I am running a Pioneer 9800BT HU . I am going 2 way active by using the Alpine PDX 4.100 and a 1.600 for the subs. Sub preout goes to the 1.600 front preout goes to the tweeters channels on the 4.100 and the rears go to my mids on the 4.100. One channel per speaker.
I just wanted to make sure that this is correct and my mids use the rear signal even though they are up front with the tweeters in my kicks
P.S. sry if this is a dumb question
Old Dec 26, 2007 | 04:40 PM
16psibrick's Avatar
16psibrick
Simplicity in Sound
does your headunit have bandpass filters on the channels specifically designed to dhtat? if not, you want to use only your front preout to the 4.100 and use that amp's onboard xover to go active, if that amp has the right xovers filters that is...if it doesnt, then you need an external xover to do the trick
b
Sleeper_Z
Sep 30, 2015 10:25 AM
EnjukuRacing
Sep 30, 2015 06:55 AM
