System Wiring: 2 Ch Amp running 4 speakers?
Old Jan 2, 2008 | 05:29 AM
KManZ's Avatar
KManZ
Ok, this weekend turned out to be pretty disappointing in terms of procurement. I ordered the amp install kit and amp, but the kit didn't even ship (ordered it on Thursday last week, 2 day shipping!), and the seller I bought the amp from is no longer an ebay member, so who knows what the hell is going to happen with that.
ANYWAYS... I canceled the amp kit, and am now looking at another. With the Alpine MRV F340, I want to run the fronts on 1 & 2, and in the future a sub on bridged 3 & 4. Will I need a 4 awg kit for this, or will I be fine with an 8 awg kit? Is it detrimental to run a larger gauge power wire than you will need?
Old Jan 2, 2008 | 06:24 AM
StreetOC192's Avatar
StreetOC192
As I said on the first page:
Originally Posted by StreetOC192
The max recommended fuse size for 8awg wire is 50 amps. The Alpine MRV-F345 has an onboard 60 amp fuse (30x2) even though I doubt it will pull 60 amps even at full volume with gains turned all the way up. As long as you keep the in-line fuse near the battery at 50 amps you should be just fine.
Ideally you should use a 4awg kit, but you can get away with an 8awg kit AS LONG AS you keep your inline fuse near the battery at or below 50amps. Just know that you may blow this fuse if you are running your 3-way system at full volume levels. DO NOT use more than a 50amp fuse in a 8awg kit.
Old Jan 2, 2008 | 06:52 AM
KManZ's Avatar
KManZ
I am looking at getting a 4 gauge kit from knukoncepts and it comes with a 120A fuse. I should be good to go with this running the amp, components and subwoofer? Just want to be sure I am not going to fry anything here.
Old Jan 2, 2008 | 07:03 AM
StreetOC192
Nope, you should be good to go with that kit.
Old Jan 2, 2008 | 07:16 AM
KManZ's Avatar
KManZ
Thanks again for helping me out.
sales@czp
Sep 23, 2019 03:30 PM
