how much??
will i get a good sound system for $2000? i will replace everything and will be adding 2 subs(have a subs box from a friend) and 2 amps. i listen to dance and trance music. i need help
thank guy
Canadian money lol my goal is SQ. i wand cd,dvd and nav if the price is right and what about amps, i need two amps one for the sub and the other for the speaker??
assuming you do not need a navi or tv headunit, 2k is very doable...i have done quite a few system in the psat for customers in the 2k range for equipment...
here is an example:
1. mid line headunit from the major manufactuers, soething wtih a good 4 volt ouput: $350
2. front stage: DLS MS6A 6.5" two way comp in kicks: $550
3. amp: DLS RA50 5 channel, front four channels will run the kicks fully active with 75 watts each driver, and send about 400 real world watts to the subs : $750
4. 2x image dynamics ID10 subs, very musical, good output and very efficient so matches well wiht the ra50's sub stage: $250
5. zenenclsoure dual 10 box: $150
done...sounds quite niec overall
b
here is an example:
b
here is an example:
b
here is an example:
b
now on the headunit.. if you are looking for CD/DVD/NAV you might have to pick an older model.. not that there is anything wrong with that.. they still perform just as great.. they just have don't have the new features
i would def. go with the dls's I let bing talk me into them and wow ill never question his knowledge or car sound again. The man knows his stuff as well as doug so you should be more then taken care of here.
thank guy. two more questions, when buying speaker is it 1 or 2 speakers in a box and second question how much will it cost to install it? again thank for helping me out
if you order a subwoofer you are only getting 1.
the cost of install will vary.. so you have to check with your local shops
I agree with the Diamond Audio comment. And you could also shave a little cash off the amplifier selection by getting a dedicated amp for your highs and another for your subs (-vs-5 Channel), while getting more power output with comparable sound Q.
