NEW KENWOOD DNX8120 EXCELON DOUBLE DIN 5.1 RCA 5V PREOUTS (Wicked CAS)
Old Oct 15, 2008 | 08:29 PM
  #321
THEDUKE's Avatar
THEDUKE
Originally Posted by TreeFiddyZee
I finally got mine to work. Thanks to Duke, Nazar and God Himself.
Drop your images (480x232) and the convert file on your thumbdrive. No folder like Duke said.
Hold down Function and Eject, then hit reset (pinhole on left).
When power light comes on, let go of the F and E buttons.
HIt OEM image, pick your image and hit OK. After picking your image, the unit should just stare at you for a bit while it is converting the image.
After it's done, arrow back to the screen that has the Kenwood and OEM image buttons. At this point, hit the reset again.
You should be good to go at this point.
I had gotten so close to getting this to work four months ago, but the convert file that I downloaded was garbage. Plus, some of the instructions were bogus, including the ones from Kenwood.
Just wondering, what image did you put on.
Old Oct 15, 2008 | 08:44 PM
  #322
Chi-TownWarrior's Avatar
Chi-TownWarrior
I works.....here is the image I used
Old Oct 16, 2008 | 02:55 AM
  #323
TreeFiddyZee's Avatar
TreeFiddyZee
Do WHAAAAT!?
Currently I'm using this one, but now that I know how to change it, it'll probably change.
Old Jan 9, 2009 | 10:29 AM
  #324
drinkingmymilk's Avatar
drinkingmymilk
bumping this thread from the past because I have a problem....
I had to jump start my Z yesterday, now the bottom lights light up blue, but I get no sound or picture on the screen. What do I have to do?
Never mind... Just needed to reset it and its good to go. Also the kenwood rep I spoke with talked me through how to change the wall papers. A+ service is the reason this is the third time I've bought a kenwood.
Old Jan 11, 2009 | 03:30 PM
  #325
tired's Avatar
tired
My main issue is the blue lighting. I would love to keep the amber and red theme throughout the car. What do you think, can anything be done about the blue lights at the bottom? Also, does the screen have a red menu option?
Thanks!
Old Jan 11, 2009 | 04:16 PM
  #326
Chi-TownWarrior
The lighting looks like it could be easily changed. If someone changes it please post a DIY I would like to have amber lighting on my 8120
Old Jan 12, 2009 | 03:40 AM
  #327
Black Spider's Avatar
Black Spider
I was able to change my skin to a fire theme. I don't remember off the top of my head the exact sequence of where it is in the menu, but it can't be that hard to figure out. It's not an exact match, but it's not bad either.
Old Jan 12, 2009 | 07:10 AM
  #328
Chi-TownWarrior
not the buttons in the GUI, the buttons on the bottom of the screen, and the blue line that runs across the bottom
Old Jan 12, 2009 | 07:13 AM
  #329
07rdsterGT's Avatar
07rdsterGT
press the "select" icon on the right top side and you will see a button on the left that says skins
Old Feb 23, 2009 | 07:32 AM
  #330
wangsta's Avatar
wangsta
I recently installed the DNX8120 on my 07 base and had a few issues that hopefully can be resolved here:
1. Can the unit play back music from NTFS formatted USB storage devices? I connected a 64Gb usb containing about 22Gb of MP3 data and the head-unit responded extremely sluggish when trying to playback and only 20-30 folders would be accessible out of 100+ in the folder.
2. The rear speakers' volume are really low, sound does come out of them but even if the output bias is set completely towards the rear they still seem too soft to be normal. Is this likely a wiring issue? or is there some type of possible cause?
Thanks in advance for any help.
Old Feb 23, 2009 | 02:23 PM
  #331
TreeFiddyZee
Do WHAAAAT!?
I'm not sure about 1., but on 2. Since you have a base, I assume you didn't have the Bose system?
Old Feb 23, 2009 | 06:50 PM
  #332
Nazar's Avatar
Nazar
Try using a USB device that is not so big and see what it does. Maybe something that has mp3 only in the hard drive.
Old Feb 24, 2009 | 07:47 AM
  #333
wangsta's Avatar
wangsta
No I don't, without taking out the unit I can't verify that I did all the wiring correctly but there is sound coming out of them at all times, just a lot softer compared to the front speakers.
A small sized USB works, i reformatted the large drive back to FAT32 and will test it out later today.
Old Feb 24, 2009 | 10:16 AM
  #334
Spork's Avatar
Spork
The headunit will only read FAT32 formatted drives IIRC.
Of course, this will limit you to 32gb.
Old Feb 24, 2009 | 07:49 PM
  #335
wangsta's Avatar
wangsta
Oh I see, thanks for clearing that up. Is the 32Gb limit apply to max storage size or the actually amount of data in the drive? I slapped about 8 gigs of music on there earlier today and it played back but I noticed it will lag some what when I'm trying to navigate through the folders but all the folders were still accessible.
Thanks for the help guys.
Old Mar 3, 2009 | 06:58 PM
  #336
sdbarker's Avatar
sdbarker
I have a couple of questions about my DDX-712:
1) Can someone hook me up with this "convert file"?
2) Can I update the images (OEM and Wallpaper) off of my iPod (if it's in disk mode, as opposed to a thumb drive) since I don't have the USB port exposed, and it'd be annoying to take my dash apart just for that?
Old Mar 3, 2009 | 07:23 PM
  #337
TreeFiddyZee
Do WHAAAAT!?
1) Shoot me your email and I can sent it to you.
2) Not sure. THEDUKE could probably answer that for you.
Old Mar 3, 2009 | 08:59 PM
  #338
sdbarker's Avatar
sdbarker
Done.
And, THEDUKE! Little help here?
Old Mar 4, 2009 | 03:36 AM
  #339
07rdsterGT's Avatar
07rdsterGT
Don't know about number two. But I'm using a 40gb external hard drive with my kenwood. I found the solution to fixing the slugishness was spliting my music up into more folders. IE
rock
rap
electronic
hard metal
maynard
funk
hed pe
Country
I tried to follow a basic rule of 10 albums per folder. Its much less slugish (actually, it pretty much eliminates it) if you do this then cram all of your albums into one giant folder.
Old Mar 5, 2009 | 05:43 PM
  #340
sdbarker's Avatar
sdbarker
Done.
Bump?
Nazar
Jun 3, 2010 05:31 AM
KuvYogHmoob
May 8, 2008 09:10 PM
