Mid in stock location w/ tweet in kick?
Anyone do it? How does it sound in a Z?
I know that it isn't ideal, but it's got to be better than tweets in the sail panels. Better alternative than coaxials?
It's not the locations that are not ideal, if installed and tuned properly it can sound absolutely fantastic......it's more the fact that the average person does not have the processing abilities to tune it correctly. You need to basically go full active for this type of setup to sound its best so that you can time-align the tweets and mids separately.
I am actually planning this type of install now. I am not 100% decided on the tweeter's exact location, but once I get everything in the car I can play with placement. The mids will most likely be in Nazar's or my home made pods on the doors......although I am really starting to consider kicks. The reason I am hesitant to do kicks is because I already have the Zenclosure door pods screwed to my door panels and if I eliminate pods altogether I will be left with holes in my door panel
But what about a regular,run-of-the-mill, passive crossover component system installed this way? It's got to sound better than the passive stock setup and tweeter location right? If so, how much better? Better than coax?
BTW, I enjoy reading your thread detailing your setup. I'm super curious about that sub.
Well, again, it really would depend on how you aim the tweet, and the actual components themselves. A metal dome tweet will sound a little warmer (typically) if installed in the kicks than it will in the sail panel. Physically you are moving the tweet closer to the woofer which is better and a little closer to a point-source setup than the sail panel tweet location.
I wrote in a thread a little while ago about my thoughts on coaxials/point-source drivers. They are the 100% ideal setup, but not enough manufacturers are devoting enough time/energy into designing audiophile quality point source or coax drivers. Also, the traditional coaxial design with the tweet on a pole extended through the center of the woofer diaphragm, the woofer will loose out on some bass response.
Now these would be some of the best point source drivers out there for the money. A pair would run about $300.
Seas Prestige T18REX/XFC
sukebe, I have done that setup in my car with diamond audio hex components. the imaging is great. lots more potential for sound adjustment on the tweets than any other location I could find without designing custom kicks. I would do it again. The only drawback is when something is placed on the passenger floorboard (groceries, backpack, someone's legs), the high's are severely impacted or of course, when you decide to sell your car, you either leave tweets there or must replace your kick panels..
I've got a set of Crystal SSCS 6.5" components w/ 1" titanium dome tweets and some CDT rear fill in my S13 that I have been thinking about pulling to install in my non-Bose 350.
I know I should just get some kicks from Bing, but I just don't want to give up my dead pedal. Everyone says you don't miss it, but I'm hardheaded like that.
Anybody got pics of their setup this way?
I am basically looking for the best possible setup while spending the least money.
Thanks for the replies, guys! Keep 'em coming!
Subarism
East Canada
Sep 23, 2015 06:22 PM
Subarism
East Canada
Sep 23, 2015 06:09 PM
ezee
May 30, 2003 08:53 PM
