Car Alarm Going Off Randomly
Old Jan 31, 2008 | 11:30 AM
Bolaz's Avatar
Bolaz
Default Car Alarm Going Off Randomly
The factory alarm in my car keeps going off randomly, like i was just sitting here watching tv and the car is in the garage and all the sudden the alarm goes off, and the other day i was somewhere, i cant remember where. The car was sitting in a parking lot with nothing around it, and the alarm went off 4 times out of nowhere. Is there a way to figure out whats causing it? or is it a way turn the sensitivity down on it?
Old Jan 31, 2008 | 11:32 AM
Sean's Avatar
Sean
there should be a "brain box" with a sensitivity adjustment screw or ****
Old Jan 31, 2008 | 11:34 AM
Bolaz's Avatar
Bolaz
Where the hell would it be?
Old Jan 31, 2008 | 11:35 AM
Sean's Avatar
Sean
start by looking under the dash, it is usually tucked in under wires and ducts to hide it.
Old Jan 31, 2008 | 11:36 AM
Bolaz's Avatar
Bolaz
Allright ill look for it, thanks
Old Feb 1, 2008 | 07:41 PM
SChetal's Avatar
SChetal
Do you have a aftermarket hood??
If so, these hoods usually cause the hood pin to trigger the alarm...
Old Feb 2, 2008 | 08:50 AM
Bolaz's Avatar
Bolaz
Yes i do!!! is there anyway to prevent it? because i could not find the brainbox for the alrasm in the car
Old Feb 2, 2008 | 03:06 PM
Sean's Avatar
Sean
tape the hood switch down, so it thinks the hood is always closed
Old Feb 3, 2008 | 07:16 AM
KPierson's Avatar
KPierson
You can also disconnect the OEM hood switch
Old Feb 3, 2008 | 09:38 AM
GXCLUSIV's Avatar
GXCLUSIV
Gymrats G35 TT
Yeah, check hood pin. On some alarms, installers will put shock sensor under hood, if water or moister builds up, it will cause alarm to trigger.
Old Feb 3, 2008 | 02:42 PM
bam025's Avatar
bam025
Yeah my cf hood does that shiat all the time....just disconnect the hood sensor.
Old Feb 4, 2008 | 09:50 AM
Bolaz's Avatar
Bolaz
Thanks for all the help guys
etkms
Jun 19, 2022 06:30 PM
kyin
Sep 29, 2015 06:57 AM
3oh5z
Exterior
Sep 22, 2015 10:09 AM
AbyteZero
Sep 22, 2015 09:17 AM
