Need more BASS
Old Feb 11, 2008 | 04:07 PM
Armando's Avatar
Armando
Default Need more BASS
I just had my system installed and love it but was wondering if I changed my amp that runs the subs to a jl audio 500/1 would it hit harder then my current setup. Can anyone offer their opinion?
this is my current setup
Kenwood ddx7019
polk momo 6500's
Alpine pdx 2.150
Alpine pdx 1.600 powering subs
Jl stealthbox 2 10'sw3v2
Thanks
Old Feb 11, 2008 | 04:15 PM
Get_Zwole's Avatar
Get_Zwole
how many watts does the 1.6 put out if its less then 250 to each then yeah you prob would get more bass.
Old Feb 11, 2008 | 04:19 PM
Armando's Avatar
Armando
it has 600 watts bro, I know it has more power but I was wondering if the jl 500/1 would hit harder.
Old Feb 11, 2008 | 05:35 PM
DVFlyer's Avatar
DVFlyer
Speed of White
Watts are watts..... I can't imagine one amp hitting harder than another given relatively good brand name gear.
Old Feb 11, 2008 | 06:10 PM
Get_Zwole's Avatar
Get_Zwole
i agree. Sell the w3v2's and get a FI q 10 lol 1000 watts to it and they are supposed to pound and sound great. Im getting rid of my w6v2 as soon as i get some money and throwin it in mine.
Old Feb 12, 2008 | 02:35 AM
StreetOC192's Avatar
StreetOC192
But the 500/1 is a JL amp YO! It's gotta hit harder!
Old Feb 12, 2008 | 02:37 AM
StreetOC192
Kenwood ddx7019
polk momo 6500's
Alpine pdx 2.150
Thanks
Tuning, tuning, tuning.
You can have all the best gear in the world, if it's not installed and tuned properly it WILL sound like POO POO. I can't imagine two 10" subs with 600 rms watts to them is not enough for anyone in a Z.
The stealthbox is wired to a 4 ohm load and can handle 1000 rms watts, so you would have best better to get the pdx 1.1000, but the 1.600 should still pound that box.
Post up 2 pics for me......
1. the settings on the 2.150
2. the settings on the 1.600
Old Feb 12, 2008 | 04:26 AM
350zspl's Avatar
350zspl
^^^^^^+1 primarily install, secondary equipment choice ^^^^
are you searching for deeper bass at frequencies 30-40 hertz , or are you searching for more volume at 41 hertz +
Old Feb 12, 2008 | 07:19 AM
DVFlyer's Avatar
DVFlyer
Speed of White
Old Feb 12, 2008 | 11:42 AM
Armando's Avatar
Armando
ok ill post the pics up this weekend. Dont have my ride right now at bodyshop getting bodykit repainted. Thanks for the 411.
Old Feb 12, 2008 | 11:48 AM
Armando's Avatar
Armando
I guess I'm use to 12's, i have never owned a pair on 10's before. At first the bass was not really present until i started to mess around with the EQ on the headunit(kenwood ddx7019) after some adjustments the bass felt like it was hitting. I def know i need a tune the install was done by a friend. I'm looking for more volume
Old Feb 12, 2008 | 11:52 AM
350zspl's Avatar
350zspl
you got pics of your hatch
Old Feb 12, 2008 | 01:57 PM
VO...'s Avatar
VO...
Administrator
Old Feb 12, 2008 | 02:12 PM
dkmesa350z's Avatar
dkmesa350z
your amp isn't the problem...I don't think the 500/1 would make a difference.
Have you played around with your amps settings?
I have the DDX-7017, so I'm familiar with the interface, what are your EQ settings? Do you have the sub level turned all the way up on the head unit?
Old Feb 12, 2008 | 02:26 PM
Armando's Avatar
Armando
I'll post pics on friday when i get it back. Its at the bodyshop getting the body kit repainted.
Old Feb 12, 2008 | 02:27 PM
Armando's Avatar
Armando
Yeah I need to read my EQ settings and get back to you. As i stated before i get my car back this friday from bodyshop.
thanks for the help man & everyone else too
Old Feb 12, 2008 | 02:28 PM
Armando's Avatar
Armando
the only reason i mentioned if the jl 500/1 would hit harder is because i have an option to trade someone, i was just curious
Old Feb 12, 2008 | 03:14 PM
StreetOC192
I personally would take the 1.600 over a 500.1 any day........but that's just me.
Old Feb 15, 2008 | 06:51 PM
Armando's Avatar
Armando
Ok, finally got my car back from bodyshop. Here are my EQ settings on my kenwood ddx 7019
treble -3 freq 12.5khz
Bass freq 80hz level 6 q factor 1.00 sublevel all the way to 5
With this setting the bass is hitting but wanted some recommendations on better settings.
thx
Old Feb 15, 2008 | 07:18 PM
dkmesa350z's Avatar
dkmesa350z
Sounds like your amp is not on an optimal setting. I would recommend setting the bass central frequency around 60 Hz and bump up the the Q factor to 1.5 to get a more gradual slope at lower and higher frequencies. This however will not help your problem much, it will just contribute to overall better sound. I have my bass set to +3 at normal listening volume and -2-0 when I turn it up loud and I am very happy with my bass output. I would suggest tuning your amp. To do this roughly, set the central frequency from 40-60 Hz, set the bass boost at about 10% and see what it sounds like as you gradually increase the gain.
Also, make sure the subwoofer level is all the way up on the HU and loudness is turned off. Set bass output to 'flat' 'low'
