Porting A Sub Enclosure
Old Feb 26, 2008 | 04:28 PM
cdoxp800's Avatar
cdoxp800
Now just what ZEnclosure do you have? I Measured the S-type. .76cf inside.
Port Length Calculator
http://www.the12volt.com/caraudio/boxcalcs.asp#por
Volume Calculator
http://www.the12volt.com/caraudio/boxcalcs.asp#rec
This may help someone.
C
Old Feb 26, 2008 | 09:37 PM
boogy886's Avatar
boogy886
Volume Calculator
C
I don't have one...yet. But they have the correct volume. The recommended volume for the W6 is 0.62cf...
I assume the more volume the better..?!
Old Feb 26, 2008 | 11:12 PM
stereoneeds's Avatar
stereoneeds
has anyone ported their zenclosure?
Old Feb 27, 2008 | 02:04 AM
StreetOC192's Avatar
StreetOC192
boogy886,
I do give you credit for trying! Not exactly sure what you have going on there though. What is the final internal volume of the enclosure you built and why are there a total of 4 vents?
As for the proper enclosure sizes for your 10W6v2:
Sealed - 0.625 fu ft.
Ported - 0.75 cu. ft.
Old Feb 27, 2008 | 04:01 AM
Lsmith9523's Avatar
Lsmith9523
AT least with your current sub-enclosure set up,,,you would not have to worry about anyone breaking in and stealing.. (joking) Nothing ventured nothing gained. At least you have some experience with ported enclosures and you had fun in the process. That is all that matters.....post up photos when you get your Zenclosure installed.
Old Feb 27, 2008 | 07:06 AM
VO...'s Avatar
VO...
Administrator
Originally Posted by StreetOC192
boogy886,
+1. Kudos for giving it a shot and thanks for the pics. That is one ugly **** of a box though.
I'm going to try my hand at it soon, but will be integrating a retangular wooden port. All I need to do is get the port specs. My enclosure will be nothing special either, just a retangular box that can sit in the hatch. I already have a perfectly built sealed enclosure. I just want to see how my sub sounds in a ported enclosure. If I'm impressed enough, I might be tempted to rip the old enclosure out and custom built something...
Old Feb 27, 2008 | 02:57 PM
boogy886's Avatar
boogy886
Sounds like a good plan to me, that'll be a fun little project.
Thanks guys! In regard to "what do I have going on there?" I have this response - It made sense in my head at the time...haha
I still can't believe I posted pics of that...quite embarrassing since that is not my quality of work
hulkout
Tuning
Sep 30, 2015 12:33 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
