Removing steering wheel controls
Old Mar 2, 2008 | 06:25 AM
USF350z's Avatar
USF350z
Default Removing steering wheel controls
I am going to be adding a double din pioneer or kenwood and I had a question about deleting the steering controls on my 06 enthusiast. Can I replace my control section with a blank, from the base model with no controls? Does that panel just pop off, or is it secured in another manner. All Responses are appreciated - thanks
Old Mar 2, 2008 | 06:47 AM
davidz33's Avatar
davidz33
You will need to remove the steering wheel in order to take off the controls.
There are DIY for removing steering wheel.
Old Mar 2, 2008 | 09:30 PM
clarkemtp's Avatar
clarkemtp
Why would you want to delete them? Just use an interface to hook them up to your new headunit.
Old Mar 3, 2008 | 04:42 AM
USF350z's Avatar
USF350z
well...that was the first thing I was planning. The last car I owned, I installed the D3 with the steering control interface(peripheral) and there was a slight delay in the operation. Hence my decision to remove steering controls. I'm not sure if their is a delay, but still, its an extra$50-$100 for the interface.
Old Mar 3, 2008 | 04:44 AM
Pokémon's Avatar
Pokémon
No aftermarket will compare to the OEM steering wheel controls. There will always be a slight delay when changing the track/volume.
Taking it off wouldn't be a bad idea actually.
Old Mar 3, 2008 | 04:54 AM
sintaxeror's Avatar
sintaxeror
I never use mine.. I was also recently thinking about just deleting them... when you do it make sure you tell us how it went.
Old Mar 3, 2008 | 05:21 AM
cbr900son's Avatar
cbr900son
i bought my interface adapter to use my controls for my kenwood 7100 and it only cost 30$
Old Mar 3, 2008 | 05:45 AM
sintaxeror's Avatar
sintaxeror
Is there any lag in the operation?
Old Mar 3, 2008 | 07:18 AM
USF350z's Avatar
USF350z
is it a direct input to the headunit, or did you have to use an IR transmitter? I didn't know Kenwood had a steering wheel control interface(other than the universal IR ones)
Obadabot
Jun 18, 2023 11:31 PM
Depravity
Oct 1, 2015 04:49 PM
